Auto tranny reverse band adjustment - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-01-2010, 06:31 PM
mfp4073's Avatar
mfp4073 mfp4073 is offline
mfp4073 is gaining momentum as a positive member of FTE.mfp4073 is gaining momentum as a positive member of FTE.
I have the astg manual, and it seems like the only adjustment to the reverse band is the reverse servo rod. I honestly cannot remember from last year when I had it out of the truck. I know there is a screw/locknut combo for the overdrive and intermediate bands. I was expecting something like that for the reverse too. Can anyone confirm this before I pull the tranny?
Old 06-02-2010, 08:15 AM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Let's bump it and see.
What's astg?
Did you pull the tranny yet?
Old 06-02-2010, 10:24 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
I am assuming you have a delayed engagement or slipping on reverse? If so the adjustment is just a one time adjustment when the new bands are first installed. Modern bands are quite thin, and by the time they start slipping, they are usually toast and need to be replaced.
Old 06-02-2010, 06:35 PM
mfp4073's Avatar
Quote:
What's astg?
ATSG is the Automatic Transmission Service Group (I spelled it wrong). They make transmission manuals that are really amazingly good. ATSG Home Page You can buy them from them directly or sometimes from tranny supply stores locally (like I did).
Tranny pulled and replaced with a used one. new one is working great. The adjustment for the reverse band is the reverse servo/piston. They make different ones with different length shafts, you put one in, if its out of tolerance you put a longer/shorter one in. BUT there are only 3 lengths/part numbers.
In my case it was limited engagement of reverse. I had several problems and have had other problems in the past. I declared the tranny a waste/curesed and got a new one!
No Reverse sleep_deprived129 1967 - 1972 F-100 & Larger F-Series Trucks 4 05-02-2016 02:24 PM
quick help transmission interchangeability Gary E Ranger & B-Series 2 09-04-2012 02:34 PM
C4 shifting problems 79FordBlake Clutch, Transmission, Differential, Axle & Transfer Case 13 11-09-2011 06:47 PM
C6 shifting hard into reverse Ken Blythen Clutch, Transmission, Differential, Axle & Transfer Case 15 06-11-2011 06:03 AM
93 fF150 C6 reverse band adjustment needledick 1987 - 1996 F150 & Larger F-Series Trucks 1 07-17-2009 08:50 AM
Tags
150, 1996, 2000, 2002, adjustemnts, adjustment, automatic, band, bands, f150, ford, ranger, reverse, transmission, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
