Diagrams of fuel bowl housing
OK i need help from any one who has ever changed the fuel heater plug that is located on the side of the fuel bowl. I dumped an entire tank of gas from this thing and I am really upset. I have a gushing diesel leak right from the center of the sensor and dont know what to do.. please I beg anyone and everyone for help with this issue. I just replaced the damn mechanical pump and all the hoses to have this happen to me right after. I think I am still lucky the damn thing sure smoked but did not catch fire thank god.
FOUND MY LEAK>>>>>>>
Check it out... It is the sensor/thermostat for the fuel heater. I removed my lead from the connector and it fell apart. now I am not spraying fuel. I have a river of fuel. Spent 45 dollars for the part and stopped my leak. I have posted a video online through photo bucket that I would like everyone to check out. I had a small leak for quite some time after replacing my fuel pump and all the hoses going to the fuel filter reservoir that I was unable to locate. Finally It gave making the leak easy to locate.
MOV03451_zps79647613.mp4 video by funkeymonkey4x4 | Photobucket
MOV03453_zps9ef12cda.mp4 video by funkeymonkey4x4 | Photobucket
hope this can help others...
Damn..... I have been leaking diesel for about a year now.. and with the first freeze of the season I had the mechanical pump fail. I decided I was going to fix my leaks. Replaced all my hoses to the fuel filter housing and the mechanical pump. when I was done I had a minor leak from somewhere on the fuel bowl and had trouble even with an inspection mirror in locating it. I was unable to locate the leak.
To make a long story short I was on my way to class and my truck began to puff out thick heavy white smoke from under the hood when I came to a stoplight. By this point my recently filled fuel tank was registering around half on the gauge. I sped back to my house where I ended up with a 1/4 tank left.
As for the part It was the the fuel heater connector / thermostat 9J294. I believe ford calls it the heater assembly F4TZ-9J294-A.
ChrisMelton78
42
08-02-2016 01:36 PM
427 fordman
12-07-2015 11:35 AM
