I need a fuse panel diagram for my '86 - Ford Truck Enthusiasts Forums
Old 03-01-2010, 04:32 PM
lemonshindig lemonshindig is offline
lemonshindig is starting off with a positive reputation.
Can't find any diagram in the truck and can't find anything in the Chilton's manual either... worthless. There are fuses missing from the panel, and my tail lights don't work. Both filaments in the bulbs are fine, and the brake lights work, so I'm guessing there's a fuse for the tail lights.
Thanks
-Matt
Old 03-01-2010, 07:13 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
At the rear of the frame, drivers side, there is a round connector that has 4 conductors.
Park lights, left turn, right turn and reverse lights.
My guess is the park light conductor has corrosion in it.
Rear side markers are not working either would be my guess?
Old 03-01-2010, 08:50 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
I would advise also check the main light switch connector under the dash and the switch contacts for burned up..... a known problem.
Truck Tech pictures from hobbies & interests photos on webshots
tail light fuse location Flyn66dtmn 1999 - 2003 7.3L Power Stroke Diesel 1 05-21-2014 03:01 PM
08 SD Tail Lights don't work. HELP 70runner 1999 to 2016 Super Duty 6 11-04-2012 02:27 PM
Trailer Tail Lights not working threeboysandadog Excursion - King of SUVs 5 08-20-2008 08:29 AM
79 F-150 Fuse Diagram idgit0488 1973 - 1979 F-100 & Larger F-Series Trucks 8 10-25-2006 02:13 PM
'97 Aero - No Dash or Tail Lights DFord Aerostar 7 12-24-2005 01:01 AM
Tags
1986, 69, 69l, 86, box, diagram, f150, f250, f350, ford, fuse, location, main, panel, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
