6.0 secondary fuel filter housing - Ford Truck Enthusiasts Forums
Old 03-01-2010, 03:59 PM
Ben Marshall Ben Marshall is offline
Ben Marshall is starting off with a positive reputation.
Ok heres one the internet and the guy at the ford dealership cant answer. Does anyone know what the spring loaded valve in the secondary fuel filter housing is called? And is it sold seperatly, or would I have to buy the whole housing?
Old 03-01-2010, 04:53 PM
w_huisman's Avatar
w_huisman w_huisman is offline
w_huisman has a good reputation on FTE.w_huisman has a good reputation on FTE.
Fuel pressure regulator? A rebuild kit can be purchased.
Old 03-01-2010, 06:42 PM
I dont think its the regulator, the manual I have shows that to be mounted to the side of the housing. The piece I broke is mounted inside the housing, and the filter slides over it. From what I can tell, it is a spring loaded valve, and the diagram i found shows it flowing back to the tank. When I changed the filter, the top part of it stuck inside the filter and broke off when I took out the filter.
Old 03-01-2010, 06:55 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Just curious, was it an A/M filter??
Old 03-01-2010, 07:06 PM
I didnt look at the old filter, I was kinda pissed at it and destroyed it getting the broken piece out...
Old 03-01-2010, 08:07 PM
Just out of curiousity, I found another post that seemeda lot like the same problem Im having...which led to the premature failing of the little plastic valve thing in my housing...and various curse words...How full should the upper filter housing be with fuel when you open it up? I barely had any, maybe a tablespoon. Would this point to a fuel pump? ($$$I hope not$$$) I do hear it come on with the key, but Im not sure what kind of pressure I have. I'll probably go after a gauge tommorrow
Old 03-01-2010, 09:23 PM
chuckf350's Avatar
chuckf350 chuckf350 is offline
chuckf350 is starting off with a positive reputation.
I bought one several months ago on ebay. It's called fuel filter return valve. Part # 1843061C92. If you go to your service department it might be called clean fuel return tube kit. When I get home tonight I'll look to see if it has another part number for you.
Old 03-01-2010, 10:06 PM
Thats the one! Thanks chuckf350
Old 03-01-2010, 11:04 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Quote:
Who installed the filter last?
Old 03-02-2010, 12:44 AM
I bought the truck about 4 months ago from a guy up in Salt Lake, so Im not sure who did the filter last. Is there any kind of precautions I should take installing the new one? I have seen that brands can play a key role in this, how are "luber Finer" from autozone? Should I get something else? Im new to diesels (this is my first one) and can use all the help i can geth
Old 03-02-2010, 01:16 AM
gtdan01 gtdan01 is offline
gtdan01 is starting off with a positive reputation.
Motorcraft/Racor filters ONLY!
I usually get the filters from my local international dealer as they are much cheaper than paying Ford for them $$$.
Last time I checked part numbers were
International part# 1847170C93
Ford part#FD-4604
Old 03-02-2010, 09:59 AM
69cj's Avatar
Absolutely do not use aftermarket filters. My guess is that is why you are in the mess that you are in now.
Old 03-02-2010, 10:11 AM
DSMMH's Avatar
DSMMH DSMMH is offline
DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.
The center post of the fuel filter is spring loaded shut when the fuel filter is removed. I know this for a fact because since I installed my AIRDOG 2 fuel pump, I was going to eliminate the secondary fuel filter to reduce restriction on fuel flow. Won't work. Motor will not start. Installed a new fuel filter and motor lit right off. When the filter is removed, fuel is shut off to the injectors.
Suggest you use Ford or Racor filters.
When you install the filter, be sure to attach it to the palstic filter top first. Then push straight down until the cap is seated against the housing. Without releasing the pressure, start threading the cap back into the filter housing.
Probably the reason your center post is broken is when the filter is installed on the center post, it does not go all the way down. When the cap is put on, the hole in the filter top does not engage properly with the little fingers in the top. When the top is screwed down, the filter ***** and puts side stress on the center post. Since the post is plastic, it snaps. Been a lot of pictures on this site with crushed and twisted filters due to improper installation.
DSMMH
Old 03-03-2010, 02:18 AM
03-6L-X's Avatar
03-6L-X 03-6L-X is offline
03-6L-X has a good reputation on FTE.03-6L-X has a good reputation on FTE.
YOu can purchase OEM and RACOR filters here:
www.dieselfiltersonline.com
Ask bismic who posted here earlier for his spreadsheets on how to keep your 6.0 running correctly, if you have not already.
Nofuel pressure + air in line after fuel filter change hank89 6.0L Power Stroke Diesel 2 05-13-2013 05:05 PM
Secondary fuel filter. pmoney1983 6.0L Power Stroke Diesel 6 08-19-2012 09:22 AM
6.4 secondary fuel filter housing on 6.0? gearloose1 6.0L Power Stroke Diesel 4 06-07-2010 07:02 PM
Secondary Fuel Filter Part # DSMMH 6.0L Power Stroke Diesel 1 02-24-2010 02:16 PM
Air getting into secondary fuel filter rob71458 6.0L Power Stroke Diesel 15 08-28-2009 09:31 PM
Tags
1843061c92, 2003, 2006, 60, broke, diesel, engine, f250, filter, ford, fuel, housing, international, liter, secondary
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
