2001 f150 2wd rear end problem - Ford Truck Enthusiasts Forums
Old 03-01-2010, 01:12 PM
blsylvia blsylvia is offline
blsylvia is starting off with a positive reputation.
Cool 2001 f150 2wd rear end problem
I have a 2001 f150xl 4.2 2wd reg. cab that I had a rear end replaced 7 months ago because it was humming (The mechanic said he couldn't find just the baring for it. (something to do with the company that made it went out of business) Now the one that was put in is doing the same. The new one had 35,000 miles on it and Because it was a used rear end I can't get my money back.What is causing this and how do I fix so it doesn't keep reoccurring ? Can you tell me what size rear end it is and what gear's are in it ? The tire's are 235/70/16 if that help's......"
Old 03-01-2010, 02:15 PM
Ron W.'s Avatar
Ron W. Ron W. is offline
Ron W. is starting off with a positive reputation.
Your mechanic is full of (insert favorite word here), find one that knows what he's doing.
The axle code is on the white sticker / decal on the door or door jamb, you will also find a description on the metal tag bolted to the differential on the rear cover.
Old 03-01-2010, 03:51 PM
airmanline airmanline is offline
airmanline is starting off with a positive reputation.
i have a 02 same truck and i had the same issue you did it might not be your rear end check your driveshaft, it has and internal skeliton sort of, and mine had lost a section inside, take it out and knock on it with your hand all over and listen for a rattle mine only broke in a spot the size of your hand and it was humming rather loudly, only way we found out was one of my buddys had a f350 with the same problem bout a week b4 mine broke
Old 03-03-2010, 08:42 AM
I just got my truck back , the mechanic couldn't find another rear end after having it for 4 weeks, so now it's up to me to find one. Here's the info I found on my door 9" axle 18 I have no idea what this mean's so there for I don't know what gear's it has..
Old 03-03-2010, 01:47 PM
call you nearest ford dealers service department and give them ur vin they can tell you what gear it is
Old 03-05-2010, 02:40 PM
Post help
Can you tell me what can to acspet to pay for a bearing kit.I really don't want to go used again.......
Old 03-05-2010, 04:15 PM
well in parts it depends on which rear end you have it can be anywhere from 100 to 300 for just the parts
Old 03-05-2010, 06:43 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is online now
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
Ron and the guys are right. They probably only made 10 million of those axles in the last 10 years !! Not being able to find a good used, or not being able to rebuild one due to "no parts" is a bad excuse. They should not go out that quick. Might want to find out why... also , which bearing ? If you have a wheel bearing going out, that can be changed out on a saturday morning in 2-3 hours for under $50.
Old 03-07-2010, 08:41 AM
96f150's Avatar
96f150 96f150 is offline
96f150 is starting off with a positive reputation.
I'll second what Steve said....along with you needing a new mechanic. the 8.8 is on of the most common rear's out there....I beleive you have the 3.31 ratio open differential. You should be able to eaily locate around 50 of them in your local surrounding area....
Rich
Ideas for a 93 f150 NightStalker101 1987 - 1996 F150 & Larger F-Series Trucks 10 12-28-2016 06:18 PM
84 f150 rear end??? jrsilverstar 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 04-24-2016 07:24 PM
My rear end bit the dust... frank5079 1987 - 1996 F150 & Larger F-Series Trucks 10 07-24-2015 07:40 AM
2001 f-150 rear end issues mtrosalie 1997 - 2003 F150 0 12-23-2014 11:51 AM
Rear end gears 77 2wd 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-09-2012 10:23 AM
Tags
1997, 2001, 2wd, axle, diff, differential, end, f150, find, ford, has, issue, problem, problems, rear, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
