Can you identify this Relay???
Old 03-01-2010, 08:28 AM
rbrad6937's Avatar
rbrad6937
rbrad6937 is offline
2000 Excursion 4X4, V10, limited.
In the engine compartment there are 2 small relay boxes right along the side of the master brake cylinder on the fender side. The first one is almost touching the power brake booster and the second one is right in front of it. The second relay box is clicking constantly even after I shut off the truck. Do you know if this relay is associated with the 4X4 system? Will it cause the 4X4 dash indicator to not light up when I try to engage into 4HI? I cannot find any reference anywhere as to what this is associated with. Can anyone help me with this?
Thanks,
Robert
Old 03-03-2010, 03:08 PM
Cowboy65's Avatar
Cowboy65
Cowboy65 is offline
Follows is a link to a PDF of your owner's manual. Look in the Fuses & Relays section beginning on page 138. There are layouts of each box with a description of each relays function.
http://www.motorcraftservice.com/pub.../00hdwog1e.pdf
Old 03-03-2010, 08:02 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
I believe you might have to save that file and email it to him. It won't let me in and probably won't let him in either. That must be a site you pay for.
I appreciate you replying and helping out.
Old 03-04-2010, 12:17 PM
subford's Avatar
subford
subford is offline
That is Free.
What the link is to is the 2000 Excursion Owner's Guide 1st printing.
To get to it go to:
http://www.motorcraftservice.com/vdi...ICLE=Excursion
Then click on "Owner's Guide 1st printing".
Then click "View Content"
Then click on "Roadside emergencies" on the left.
You also download the whole manual.
Old 03-04-2010, 12:40 PM
Cowboy65's Avatar
Cowboy65
Cowboy65 is offline
My link is to a free site, however I'm not quite sure why it doesn't work from the previous post. It may have to do with a security certificate problem. Try the following link instead:
https://www.flmowner.com/servlet/Con.../Page/HomePage
At the home page select "GloveBox" from the upper row menu, then "Owners Guide", then select the make, model, & year of the vehicle.
rbrad6937
Electrical Systems/Wiring
03-04-2015 06:34 AM
robert_l_ross
Modular V10 (6.8l)
06-11-2011 01:23 AM
rbrad6937
03-05-2010 09:56 AM
projectdagger
01-29-2009 05:07 AM
Jack Hoover
1997 - 2003 F150
06-02-2008 11:21 AM
Quick Reply: Can you identify this Relay???
