Can you identify this Relay??? - Ford Truck Enthusiasts Forums
Old 03-01-2010, 08:28 AM
rbrad6937 rbrad6937 is offline
rbrad6937 is starting off with a positive reputation.
2000 Excursion 4X4, V10, limited.
In the engine compartment there are 2 small relay boxes right along the side of the master brake cylinder on the fender side. The first one is almost touching the power brake booster and the second one is right in front of it. The second relay box is clicking constantly even after I shut off the truck. Do you know if this relay is associated with the 4X4 system? Will it cause the 4X4 dash indicator to not light up when I try to engage into 4HI? I cannot find any reference anywhere as to what this is associated with. Can anyone help me with this?
Thanks,
Robert
Old 03-03-2010, 03:08 PM
Cowboy65's Avatar
Cowboy65 Cowboy65 is offline
Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.
Follows is a link to a PDF of your owner's manual. Look in the Fuses & Relays section beginning on page 138. There are layouts of each box with a description of each relays function.
http://www.motorcraftservice.com/pub.../00hdwog1e.pdf
Old 03-03-2010, 08:02 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I believe you might have to save that file and email it to him. It won't let me in and probably won't let him in either. That must be a site you pay for.
I appreciate you replying and helping out.
Old 03-04-2010, 12:17 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
That is Free.
What the link is to is the 2000 Excursion Owner's Guide 1st printing.
To get to it go to:
http://www.motorcraftservice.com/vdi...ICLE=Excursion
Then click on "Owner's Guide 1st printing".
Then click "View Content"
Then click on "Roadside emergencies" on the left.
You also download the whole manual.
Old 03-04-2010, 12:40 PM
Cowboy65's Avatar
My link is to a free site, however I'm not quite sure why it doesn't work from the previous post. It may have to do with a security certificate problem. Try the following link instead:
https://www.flmowner.com/servlet/Con.../Page/HomePage
At the home page select "GloveBox" from the upper row menu, then "Owners Guide", then select the make, model, & year of the vehicle.
2000 Excursion Power Window/Lock problems rbrad6937 Electrical Systems/Wiring 9 03-04-2015 06:34 AM
2000 V10 help robert_l_ross Modular V10 (6.8l) 4 06-11-2011 01:23 AM
Need help with relay rbrad6937 Excursion - King of SUVs 1 03-05-2010 09:56 AM
part number request please for an 89 F-150 projectdagger 1987 - 1996 F150 & Larger F-Series Trucks 5 01-29-2009 05:07 AM
2002 F150 Power Window won't go up! Jack Hoover 1997 - 2003 F150 6 06-02-2008 11:21 AM
Tags
2000, diesel, excursion, ford, id, identify, light, relay, relays, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
