No Throttle
No Throttle
The truck from hell is back to screwing up again,frustraiting!I heard that the wires can rub through under the master cylinder,i checked that,it started rubbing through the sheathing but not the wires.I replaced the sheathing and zip tied it away from the lines so it wouldn't rub anymore.I also washed the motor so i could make sure the electrical plugs and wires over the valve covers were ok.They looked fine too.Any other ideas?
Sorry haven't bine around.I put a new peddle it fixed it for a short period of time (three of them).Now it seems to be working as far as responce.But recently at light throttle it started surging going slow,coming up with code 231.It says can be caused by secondary fuel pump circuit failure.Now my truck is doing it cruising down the highway,but if you put it in cruise it's fine.Now the only code it has is for the peddle.
I gave Ed my VIN and for my application the throttle assembly is $77. I guess i'll have to ink up on that to see if it helps me.
Another thought here, guys.
The reason I asked LRODEO his year and fuse number is that the infamous wear-through of the insulation on the wires to the Overdrive Cancel Switch blows the fuse (under-dash #19) supplying the Idle Validation Switch, too.
His is an earlier year, I believe the same as yours, Robin, and is wired differently, having two fuse/relay blocks.
Pop
Pop
My truck is a 1999 and i am not sure the fuse number it is a small red 10 fuse, i have replaced the pedal, i changed the fuse and drove it maybe 50 miles and the fuse went again, i also lose my wait to start light and other dash lights.
the last time it stopped working when i got out of the truck i could smell a burnt smell so i am thinking i have something shorting out but i am not having problem with anything else on my truck other than the pedal
Gotta' pretty-good idea what your problem is, but first we need you to confirm what fuse number you blew from the diagram below:
If it's Fuse #19, then it's the wiring to your Overdrive Cancel Switch that's worn through the insulation and shorting out. Read this:
https://www.ford-trucks.com/forums/9...ml#post8749686
Fix it with Scotch #33 electrical tape after you've gotten all the metal spotlessly clean so the tape will stick to it where it's necessary. Don't just wrap the wires, but coat the metal with at least two layers of tape where the wires get close or touch.
Pop
Pop
#29
The wires are tiny and the insulation is thin. It wears through easily.
Get that Scotch 33+ electrical tape. It's the best there is, with the best adhesive. Make sure the metal is CLEAN with a good solvent to get good adhesion. Use a couple layers of tape.
Move the shift lever through the gears while watching that wire. Put tape anywhere the wire gets near metal.
Pop
Pop
#30
had same problem on my 03 excursion. wires in the steering column were rubbed bare and would blow the fuse when steering right or at random times when shifting. That fuse controlled the fuel pedal therefore it would start and idle fine but no acceleration.
May not be your exact problem but sounds similiar.
