1996 f150 and gt40p heads
The gt40 heads do not need special headers. The Gt-40P heads need special headers or special spark plug wires.
I would say definitely yes. The E7 heads are quite restrictive, and the GT40/GT40P heads are a great way to help improve power (plus the truck looks stock, making it a good "sleeper" mod), It's definitely worth it, if you don't mind the very limited choice of manifolds/headers that the GT40P allows. I would say this is a great thing to do to your truck. It's high on my list of things to do. (following new gearing and exhaust)
I am running the cheapie pacesetter/summit headers on my 351w with Gt40P heads. Passenger side fit great, driver side required a small bit of clearanceing by hammer so that the #7 plug wire did not touch the tube. I am running Taylor 90 degree wires. I have not tried to change the plugs in the truck yet, I am sure it is going to suck big time, but for 300 dollars the power gains are well worth it.
I am running gt40 heads on my stock 302. I would suggest shorty headers. I am running heddman long tube headers and they can be a pain to work with. Like the starter, tranny pan ect. IMO you wont see the difference in short vs. long with only gt40 heads as a mod. When you install them, dont use Felpro's front and rear seal for the lower manifold. Use ultra black RTV and be generous!
on
GT40 heads are identified by 3 vertical bars on the front face of the head and the letters "GT" cast into the head at the corner. The P version has 4 vertical bars and "GTP" cast into the head. Mid year '96 was the cut over from GT to the P heads apparnetly.
GT40Heads1 on Flickr - Photo Sharing!
MR KROGOTH
23
03-27-2017 09:45 PM
brandonwsmith66
02-21-2017 08:05 PM
1976fordguy
02-02-2015 09:36 PM
caleb_ford
12-07-2011 07:08 AM
