Foglights
Foglights
I have an 2008 ford ranger that didn't come with foglights or the wiring for foglights. I have installed foglights on the truck using the headlight switch for this ranger if it had come with foglights from factory. The gray and purple wire is in the harness at headlight switch conector and goes over to SJB module behind pass. kick panel. I have 12 volts at SJB module with foglights on gray and purple wire. I can't seem to get indicator on instrument panel to light with foglights on. According to the wiring schematic it shows "canbuss" communications from SJB module to instrument panel. Does the SBJ module have to be programmed to operate the indicator on dash.
Thanks, ctspruill
2008 ford ranger XL
2.3L with auto
2002 F150 FX4
BBK headers,superchip powergrammer
16X10 AE 589's
285/75/16 bridestone revo's
Thanks, ctspruill
2008 ford ranger XL
2.3L with auto
2002 F150 FX4
16X10 AE 589's
foglights
Went to ford dealer today about canbus communication between instrument cluster and SJB module. Shop tech contacted engineer with ford over issue. Ford says since truck didn't come with the option from the factory. It doesn't offer an dealer option for foglights and doesn't recommend any alterations to truck. Engineer says this would be considered a modication and could void warranty. I also recieved the printout from the dealer with the communication between shop tech and engineer. Sounds like more BS from ford.
kaatinthehaat
11-16-2003 10:41 PM
