Anyone using GreaseCar and DP Tuner? - Ford Truck Enthusiasts Forums
Old 02-28-2010, 01:16 AM
MikeWorcester911's Avatar
MikeWorcester911 MikeWorcester911 is offline
MikeWorcester911 is starting off with a positive reputation.
I just installed a GreaseCar kit in my '00 and was wondering if anyone was running a DP Tuner with WVO. I'm told there will be noticeable power differences when running on WVO, so I'm curious if those losses are consistent with the power gained by the programs I have.
While I'm at it, I'm also curious if anyone has had any problems with leaks in their GreaseCar valves? I bought my kit used off eBay and started by installing everything so I could drive the truck, but not ready to run oil yet. I noticed I had diesel fuel leaking out of the oil return port. I'm told now, after several other, unrelated electrical issues have been resolved that I am probably pulling air in from the oil inlet (when running on diesel) which causes me fuel starvation issues including stuttering and loss of power. I didn't buy my kit from GreaseCar so their policy keeps me from getting much support without paying for it. Anyone know if they have a valve rebuild kit?
Old 02-28-2010, 12:07 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
Rushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud of
I use the DP Tuner with Bio and it works just fine. Don't know about WVO.
Advice on WVO in a 6.9idi VaFordman26 Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 01-11-2013 09:14 AM
Anyone using GreaseCar with DP Tuner MikeWorcester911 1999 - 2003 7.3L Power Stroke Diesel 11 03-02-2010 01:44 PM
grease car valves and fuel pressure question? ms1780 Bio-diesel, Propane & Alternative Diesel Engine Fuels 0 11-24-2008 02:32 PM
WVO setups Smokin' 1999 - 2003 7.3L Power Stroke Diesel 30 06-04-2008 07:06 AM
Diesel running on vegetable oil. clockgod1 6.0L Power Stroke Diesel 15 07-14-2004 06:14 PM
Tags
bronco, car, dp, econoline, excursion, ford, grease, greasecar, kit, run, sale, tuner, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
