05 Expy Park Assist help
I think in earlier years there were bumpers that had two visible sensors and one central sonar (or radar, whichever the visible ones aren't). As far as the intermittant check system warning ti sounds like you have a loose connection somewhere. I had this on my '04 and it was in the left rear tailight where the wires for the system meet up with the main wiring.
I got under the back today and checked the wiring harness for the "P.A.". There are two visible sensors on the rear bumper with wires going to both and a point in the center that the wiring harness is also plugged into, this center connection has no external sensor. Is it possible that the wrong bumper cover was used as a replacement and is covering the center sensor(s)?
Ditto on my 05 Limited having 4 sensors on the back, but "knock on wood" no problems with that part of the vehicle yet. I'd take a look under the bumper at the connectors you have. I'm thinking the 05 Navi's only had two sensors??
edit: okay I type slow, you posted your checking out before I hit submit. I'd vote for the wrong bumper cover used. I also think the 06 or ups only had two sensors
Right or left?
I have an 06 Expedition with park assist not working. I checked the codes and it says the right rear and right central sensors aren't working. I think based on the situation that this is right looking from the rear rather than from the front, but I can't find anything that says which way. Anybody know if it's right from rear for sure?
Pele
07-14-2016 08:20 AM
mecdac
01-21-2014 09:28 AM
