05 Expy Park Assist help - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 02-27-2010, 10:48 PM
OS2_Caldwell OS2_Caldwell is offline
OS2_Caldwell is starting off with a positive reputation.
I recently purchased a 2005 Expedition XLT. It has had a rear bumper replacement at some point due to a minor accident. The park assist will not engage, when I try it says "check park assist". There are only two sensors on the bumper, is this right??
Old 02-28-2010, 12:07 AM
aft2005exp aft2005exp is offline
aft2005exp is starting off with a positive reputation.
I have 2005 EXP EB 4x4 that has original rear bumper and that has four sensors. I am not sure if the XLT is different. But sometimes when I shift into drive from reverse, the message center displays "check park assist" as well. Anyone know why?? Truck has 96k
Old 02-28-2010, 10:57 AM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is online now
alwaysfords41 is gaining momentum as a positive member of FTE.
I think in earlier years there were bumpers that had two visible sensors and one central sonar (or radar, whichever the visible ones aren't). As far as the intermittant check system warning ti sounds like you have a loose connection somewhere. I had this on my '04 and it was in the left rear tailight where the wires for the system meet up with the main wiring.
Old 02-28-2010, 01:55 PM
Thanks, If anyone knows how many sensors there are from the factory on a 2005 XLT please post it. I am going to get under the back and check all the connections.
Old 02-28-2010, 02:01 PM
carlos1212's Avatar
carlos1212 carlos1212 is offline
carlos1212 is starting off with a positive reputation.
my 05 limited has 4 sensors in the back and also about 1 out of 15 times I put it in reverse it also displays check park assist
Old 02-28-2010, 06:17 PM
I got under the back today and checked the wiring harness for the "P.A.". There are two visible sensors on the rear bumper with wires going to both and a point in the center that the wiring harness is also plugged into, this center connection has no external sensor. Is it possible that the wrong bumper cover was used as a replacement and is covering the center sensor(s)?
Old 02-28-2010, 06:22 PM
Privateer Privateer is offline
Privateer is starting off with a positive reputation.
Ditto on my 05 Limited having 4 sensors on the back, but "knock on wood" no problems with that part of the vehicle yet. I'd take a look under the bumper at the connectors you have. I'm thinking the 05 Navi's only had two sensors??
edit: okay I type slow, you posted your checking out before I hit submit. I'd vote for the wrong bumper cover used. I also think the 06 or ups only had two sensors
Old 02-28-2010, 06:26 PM
That could explain it... It might be a navi rear on me Expy. The wiring harnesses would probably mate-up at the tail light connector.
Old 07-26-2014, 11:28 AM
strider73 strider73 is offline
strider73 is starting off with a positive reputation.
Right or left?
I have an 06 Expedition with park assist not working. I checked the codes and it says the right rear and right central sensors aren't working. I think based on the situation that this is right looking from the rear rather than from the front, but I can't find anything that says which way. Anybody know if it's right from rear for sure?
Old 07-26-2014, 07:29 PM
If it says right it would be the passenger side.
Old 07-26-2014, 09:01 PM
thanks.
Old 07-27-2014, 01:23 AM
alloro alloro is online now
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
All vehicle part location references are always as if you are sitting in the driver's seat.
Installing OE Parking Assist? Is the wiring there? Pele Excursion - King of SUVs 2 07-14-2016 09:20 AM
WTB: 04-07 F350 Front Bumper, Rear Bumper, & Tailgate Hellbringer WTB - Parts & other 2 10-27-2014 08:59 PM
Rear park assist problems brentkhack Expedition & Navigator 0 07-18-2013 04:39 PM
Is Chrome Rear Bumper one piece or two? royb 2009 - 2014 F150 1 09-28-2010 09:47 AM
Parking assist aero993 Excursion - King of SUVs 8 03-11-2010 06:17 PM
Tags
2003, 2008, assist, bumper, bumpers, check, expedition, ford, lincoln, navigator, park, problems, rear, replacement, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
