Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-27-2010, 12:06 PM
blueeyedfordguy's Avatar
blueeyedfordguy blueeyedfordguy is offline
Garage is empty, add now
blueeyedfordguy is starting off with a positive reputation.
ethanol in gasoline
i've been told up to there is now 5% ethanol in gasoline. This causes problems in the older engines, but yet the newer engines, are designed to run on it. By the next few years, im told it may be 20% ethanol. I buy and run recreational gasoline which is 100% gas and run that in my small engines. Its 90 octane. Works well. How much of a problem does this new gas cause in the older engines, lets say 1990 and older. I use have used lucas, and seafoam fuel additives and they help with the lack of lubrication in the new gasoline. Whats your guys imput??
  #2 (permalink)
Old 02-28-2010, 12:44 PM
Lead Head Lead Head is offline
Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.
Don't worry about it. All gas is E-10 (10% Ethanol) not E-5. I run it in my Ranger, its been fine, I know plenty of people that run it in vehicles far older without any issues either.
I run it in my all original 1970 Cub Cadet, complete with the original 40 year old fuel line and carb gaskets. No problem at all. Also run it in my 1963 Generator with a 9HP Briggs. No issues. Also, Gas was never a lubricant. It is, and has always been a solvent. Hence why even before they started adding Ethanol to fuel if you accidentally put gas in your diesel vehicle, it was pretty much guaranteed to destroy the injectors and injection pump.
IMO, those gas additives are a waste of money. Unless you plan on storing gas for extended periods of time (3 months + ) don't bother. There are guys that will say that the "new" gas goes bad in a month. I stored my dirtbike with the E-10 fuel in the tank for about 6 months during the winter last year. Come spring it started right up second kick, and ran just fine. Those same people will also probably tell you it eats and destroys fuel components, such as aluminum carbs. Once again, my ancient tractor and generator have never had a single issue.
Maybe I'm just lucky?
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #3 (permalink)
Old 02-28-2010, 07:51 PM
creich68's Avatar
creich68 creich68 is offline
creich68 is gaining momentum as a positive member of FTE.
The marine industry has seen some issues with fiberglass fuel tanks and various fuel system parts in boats. The ethanol seems to be "eating" at the tanks and causing the fiberglass to separate. Some boat manufactures have even resorted to only installing metal tanks in their new boats. Also, ethanol blended fuels seem to be affecting the valve seats for boat engines due to the extreme operating conditions boat engines are subjected to. That's why most marinas only sell fuel with 0% ethanol and are not required to sell E10. At least in Missouri they're not required to sell it. It could be different in other states.
Now back on topic, there hasn't been a real concern for running it in vehicles.
__________________
-Clay
2002 F-250 7.3 PSD - AIH, CCV, 6637, 4" MBRP, Riffraff OCR, 6.0 IC/TC, FRx, Billet Wheel, DP Tuner 80E, Isspro Performax
1968 Ford Mustang - 302, T-5, MGW Short Throw, MSD Ignition, Edelbrock Intake/Carb, Shelby/Kelsey Hayes Front Disc
  #4 (permalink)
Old 03-01-2010, 11:21 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
I dont understand the valve seat claim. Other than the opinion of a marina owner, what is the reason? Unleaded fuel also was supposed to destroy old engines due to "valve recession". It never really became much of a problem. Our 283ci Chevy V-8's and LA block Mopars (273ci and 318ci) from the early 1960s were fine.
Pure gasoline is unavailable in California, all E10. Yes, fiberglass tanks are an issue. Due to the risk of phase separation at cold temperatures, aircraft certified to run on automotive gasoline should not run E10, so are forced to use leaded aviation gasoline. We tried to get BP to sell our airport straight gasoline and they refused, afraid of fines if the fuel found its way into road vehicles. Yet, they supply the 100LL, same legal issue. I cant imagine boat marinas can get straight gasoline here either.
Bottom line, I run a 1969 VW and ancient Briggs and Stratton small engines on 87 AKI E10 with absolutely no issues. The original intent of oxygenated fuel was to slightly lean out old fixed jet carbed engines. It works. They need a little extra choke to start, but run well when warmed up. Spark plugs are a nice tan color. I remember more black soot in the old days.
Jim
  #5 (permalink)
Old 03-01-2010, 11:57 AM
creich68's Avatar
I believe the valve seat issues are due to the slightly higher combustion temps seen by E10 in boat engines which in some cases, not all, lead to premature wear of the seat itself. This may not be a trend, but I've observed this in boating mag articles and through talking with marine mechanics. Boat engines just have much more extreme operating conditions than vehicles (holding high rpms for a long durations with a high engine load and with little engine compartment ventilation). I haven't really heard any vapor lock issues with E10. I'm curious if E10 plays any role in vapor lock.
That's unfortunate you can't buy pure gasoline in CA. Pretty much every marina/gas dock i've been to in MO sells pure gasoline.
__________________
-Clay
  #6 (permalink)
Old 03-05-2010, 09:30 PM
GLR's Avatar
GLR GLR is online now
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
I found I get less fuel mileage with 10% (fed requirement??) Local fuel companies in NY had to replace seals in there tank trucks when they had to switch to 10%. If ethanol is supposed to cut down on emissions - what good does it really do when you have to use more?
__________________
[/SIGPIC]George 54 F100, 78 F150, 79 F150, 86 F250, 87 F250 Member #5 Boy you ain't Right Club Official Slackmaster #15
  #7 (permalink)
Old 03-06-2010, 11:39 PM
fishheds fishheds is offline
fishheds is starting off with a positive reputation.
Well,last fall,my center console w/Mariner outboard started acting up.I called my boat mechanic buddy and HE told ME why I was calling.Said the E10 is breaking down fuel tanks,hoses and seals and clogging up injectors.West Marine is selling out of ~80 micron remote filter kits.
Installing my filter set-up tomorrow and rebuilding my injectors next weekend.
  #8 (permalink)
Old 03-07-2010, 07:45 PM
Quote:
thank you, thank you, that is my point. If we have to use more gas, what is the point if there are less emisions? The only way I found to fix some of these fuel problems is adding a lucas fuel additive or something like that. Other wise I get 90 octane recreation gas, which has no etanol even in it. Runs good in an old truck. Smells good too. I've heard we will see it get way worse maybe.
  #9 (permalink)
Old 03-08-2010, 08:56 AM
Sounds like similar operating cycle as aircraft engines, which operate at full power for takeoff and climb and almost full power in cruise. Also they have tight cowlings. Still, boats have unlimited water cooling available, so cylinder head temps have to be much lower. As with aviation, magazine articles and many mechanics perpetuate myths, which turn out not to be true. "Leaner is hotter. Richer is cooler" is the worst one that has finally been proven wrong with fully instrumented aircraft engines. I doubt if anyone has put CHT and EGT probes on every cylinder of a marine engine and adjusted the mixtures real time to see what really happens.
Jim
  #10 (permalink)
Old 03-08-2010, 11:13 AM
creich68's Avatar
Quote:
Jim
They do have unlimited water cooling but during the summer when water temps are nearing 85 degrees, the cooling efficiency drops off. Like you pointed out with aircraft engines, marine engines do have to operate at near full power to get on plane and still maintain most of that power at cruise. Also, take into affect that the water is no where clean, the cooling passages corrode over time due to impurities, especially in saltwater, and even get completely blocked in extreme cases causing hot spots. I'll agree that the valve seat issue is isolated, but has happened more so since ethanol has been introduced into fuel. They should put pyros in the exhaust to see if they really is an effect from ethanol or if it's a myth. I have a feeling, even with research, the cases will most likely still be isolated.
__________________
-Clay
  #11 (permalink)
Old 03-08-2010, 09:00 PM
Steina Steina is offline
CO River Rat
Steina is gaining momentum as a positive member of FTE.Steina is gaining momentum as a positive member of FTE.
The EPA is considering a proposal for E15, with a decision possibly by this summer. The corn-growing states are all for it, but I'm not sure a 50% increase in ethanol is a good idea without lots of testing; personally, I hope this is not OKed.
Steve
__________________
Black 2004 Explorer XLT Sport 4.6L as my "boat hauler" for Lake Havasu/Lake Mohave runs
Smokestone 2010 Fusion SE 3.0L for Wifey
"I used to be wishy-washy, but now I'm not sure"
  #12 (permalink)
Old 03-09-2010, 09:10 AM
Quote:
Steve
Yeah, I highly agree. Didn't hear about that one. Doesn't save on emissons if we get less miles per gallon on gasoline! Isn't E85 15% ethanol, and 85% gasoline? Thats just not good, because in a vehicle that is not designed to run E85, the mileage is reduced noticeable, even if it is a few cents cheeper per gallon. Its too bad. I might have to start buying more Recreational off road gas if this effects me as much as it sounds!
  #13 (permalink)
Old 03-09-2010, 02:31 PM
CO River Rat
No, E85 has 85% ethanol which is supposed to run fine in Flex Fuel vehicles like my wife's Fusion. I say "supposed to" 'cause I'm planning on never using it. The EPA took comments last year on E15 (I voted against it), but I don't know how many $$$ the corn-belt states are willing to spend to pass this; probably lots. If it passes without further testing I think the EPA is in for a firestorm of complaints.
Steve
__________________
  #14 (permalink)
Old 03-09-2010, 03:01 PM
GLR's Avatar
Just wrote to the EPA doubt if it will do any good. U.S. Environmental Protection Agency lots of regulations on the site - scary.
__________________
  #15 (permalink)
Old 03-10-2010, 02:32 AM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
E10 sucks already, and E15 would be even worse.....
Tags
2010, accidently, color, diesel, e10, e85, f150, ford, gas, gasoline, plug, put, recreational, spark, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
