Changeing HFCM - Ford Truck Enthusiasts Forums
Changeing HFCM
Old 02-27-2010, 07:25 AM
mh5500 mh5500 is offline
mh5500 is starting off with a positive reputation.
Changeing HFCM
Any special wrenches need to change the hfcm?
Old 02-27-2010, 08:28 AM
Whitey Ford's Avatar
Whitey Ford Whitey Ford is offline
FTE-Spread The Knowledge
Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.
Manifold Cover / WIF Sensor Installation/Inspection Procedure.
<TABLE border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD itxtvisited="1"></TD><TD width=100 itxtvisited="1">CAUTION:</TD><TD itxtvisited="1">SMOKING OR AN OPEN FLAME OF ANY TYPE IS PROHIBITED WHEN WORKING NEAR FUEL OR FUEL VAPOR.</TD></TR></TBODY></TABLE>
  1. <LI itxtvisited="1">Disconnect both battery ground cables. Refer to Workshop Manual, Section 414-01. <LI itxtvisited="1">Raise and support the vehicle. Refer to Workshop Manual, Section 100-02. <LI itxtvisited="1">Open the fuel/water separator drain plug to release contents (Figure 1).
    Figure 1 - Article 06-6-5
    <LI itxtvisited="1">Disconnect the fuel pump, heater, water in fuel electrical connectors from HFCM (Figure 2).
    Figure 2 - Article 06-6-5
    <LI itxtvisited="1">Disconnect HFCM electrical harness from main vehicle harness. <LI itxtvisited="1">Disconnect the fuel hoses from HFCM.
    1. <LI itxtvisited="1">Remove the fuel hose retaining clips and discard. Disconnect the fuel hoses closest to the engine (Figure 3 number 1).
      Figure 3 - Article 06-6-5
    2. Press in the retaining clips and release the fuel hoses closest to the fuel <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_25_0>tank</NOBR> (Figure 3 number 2).
    <LI itxtvisited="1">Remove the screws and the old fuel manifold cover (Figure 4).
    Figure 4 - Article 06-6-5
    <LI itxtvisited="1">Inspect/clean debris from the HFCM water reservoir housing (max. 25 psi air). <LI itxtvisited="1">Install the new manifold and screws and torque to 44 lb-in (5 N-m) (Figure 5).
    Figure 5 - Article 06-6-5
    <LI itxtvisited="1">Install the new electrical harness and reconnect/reinstall fuel lines. Electrical harness will have connectors for the pump, for the water in fuel sensor, and one that connects to the main vehicle harness. <LI itxtvisited="1">Verify that there are no fuel leaks from the HFCM.
  2. Remove and discard heater 30 amp (J-case style) heater fuse.
    1. For 2003-2004 Model Years, remove 30 amp Fuse F2.105 located in Central Junction Box (CJB). Refer to 2003 or 2004 Ford F-Super Duty (F250/350) Wiring Diagrams (EVTM), Section 11 (pages 1-3).
    2. For 2005 Model Year, remove 30 amp Fuse F1.7 located in the engine Battery Junction Box (BJB). Refer to 2005 Ford F-Super Duty (F250/350) Wiring Diagrams, Section 11 (pages 4-5).
      <TABLE border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD width=80 itxtvisited="1">NOTE:</TD><TD itxtvisited="1">DO NOT REINSTALL HEATER FUSE (FUSE IS NOT REQUIRED WITH NEW HFCM MANIFOLD).</TD></TR></TBODY></TABLE>
<TABLE border=1 cellSpacing=0 cellPadding=3 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TH align=middle itxtvisited="1">PART NUMBER</TH><TH align=middle itxtvisited="1">PART NAME</TH></TR><TR itxtvisited="1"><TD class=NOBOTTOMBORDER align=left itxtvisited="1">6C3Z-9B249-B</TD><TD class=NOBOTTOMBORDER align=left itxtvisited="1">HFCM Kit</TD></TR></TBODY></TABLE>
Old 02-27-2010, 08:40 AM
Just about any auto parts store will have the fuel line removal tools. About $15 for the whole set (1/4", 5/16", 3/8" and 1/2"). You'll need the 5/16" and 3/8" for the Ford lines.
Good luck. Let us know how it goes, maybe pictures.
Old 02-27-2010, 09:00 AM
Old 02-27-2010, 10:09 AM
teppler's Avatar
teppler teppler is offline
teppler is gaining momentum as a positive member of FTE.
Most auto parts have a loan program for special tools might check with them
6.7 HFCM conversion? rotun 6.0L Power Stroke Diesel 2 10-11-2016 11:51 AM
What is the this in inside Hfcm ? Fell off and truck losing power? KLINE925 6.0L Power Stroke Diesel 12 04-03-2014 02:29 AM
WIF light on! Need help! Restlesswildman 6.0L Power Stroke Diesel 19 02-21-2014 10:55 PM
HFCM noise duallyking 6.0L Power Stroke Diesel 7 02-10-2009 02:34 PM
HFCM First Fit, FF, fuel filter bnmccoy 6.0L Power Stroke Diesel 6 11-06-2006 12:37 AM
Tags
04, 06, 60, clean, cleaning, cover, diesel, f250, ford, hfcm, hfcm change, manifold, powerstroke, procedure, replace hfcm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
