Key wont' crank it, but jumping the solenoid will - Ford Truck Enthusiasts Forums
Old 02-26-2010, 08:42 PM
btorear btorear is offline
btorear is starting off with a positive reputation.
i have an '89 ford f150 4.9L six cyl 4X4. recently i got in to start it and the key wouldn't start it. I was able to start it by using a remote starter swith attatched to the solenoid (lucky i had it with me). I can turn the key and nothing (doesn't even feel like it "wants" to turn, and doesn't really spring back from the start position to the run position). tried changing the ignition cylinder on the column with a new one, and it's still the same. I've worked on Ford trucks (shadetree, not professoinally ha ha) for yrs, and oddly enough never come across this conundrum). could it have something to do with the neutral safety switch, ot the clutch switch? I'm guessing at that, but it's the only thing i can remotely think of. Hate to sound like a dummy, but there's no shame in askin, then learning something new . Any help would be greatly appreciated.
Old 02-26-2010, 09:08 PM
Ottneys250 Ottneys250 is offline
Ottneys250 is starting off with a positive reputation.
Hey buddy
Im not to shur, but I just had the same problem with my 5.0. My dad fixed it and I belive i was working under the hood and knocked the fuel relay swich loose and we put a new one on. It was like a little black box on the right side, and it started right up
Maby someone else with chime in ?
Old 02-26-2010, 09:18 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
sounds like the ignition actuator is bad.
Old 02-26-2010, 09:58 PM
nnero's Avatar
nnero nnero is offline
nnero is gaining momentum as a positive member of FTE.
I agree with quicklook. The actuator is like $10 at NAPA though it is a pain to replace. You have to remove the steering wheel and parts of the steering column.
Old 02-26-2010, 10:34 PM
well i already have all of that disassembled, so that part is done. i was exploring to see if it was something simple
Old 02-26-2010, 11:39 PM
Thnks so mush nnero and quicklook. I'm almost positive it is the ignition actuator. after reading your advice, i did a search on this forum and found a link to a step by step removal and installation with pictures to guide me. You've been most helpful. I appreciate it.
1999 E250 - Key On then Start Solenoid Noise ? Steve in NC 1968-2013 Full Size Vans 6 11-04-2014 10:47 PM
1980 F100 turn key, won't start then everything dies. Uncle Paul 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-22-2014 10:33 AM
Factory remote start doesn't work after new keys LucasMN 1997 - 2003 F150 3 10-12-2012 11:36 AM
1995 F-250 7.3L Ignition Switch Issue Lee In Leetonia 1987 - 1996 F150 & Larger F-Series Trucks 1 07-02-2011 07:58 AM
FORD "GOLD" REMOTE START DOESN'T! MrBSS Electrical Systems/Wiring 3 01-17-2005 01:11 AM
Tags
150, 87, 89, change, column, crank, f150, ford, hook, jumping, solenoid, starts, steering, wires, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
