89 f250 4x4 brakes
89 f250 4x4 brakes
i have an 89 f250 hd with the dana 50 front ttb now i had a sticky caliper which in turn destroyed the rotor now i see 3 different choices for rotors some come with the hub and others do not some are for the 3800 lb axle others are for the heavier axle. Im assuming i need the 4600 lb axle. my question is do the rotors seperate from the hub or do i have to buy the whole assembly theres a big difference in price and nothing is wrong with my hubs
thanks Kyle
thanks Kyle
The rotors do come off the hubs, its cheaper that way, but way more work, you need to pound all the studs out and then the rotor will have to get hit off the hub.
I got these from ebay for my F350
If you have never done ball joints id do em too, and the bearings, and axle shaft u joints. I tend to do whatever is around what I have to do, just so I dont have to redo it later.
