Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Colorado Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Colorado Chapter Join Chapter, Leader: RIKIL
  #1 (permalink)
Old 01-21-2003, 01:07 AM
dassmoof dassmoof is offline
Garage is empty, add now
dassmoof is starting off with a positive reputation.
Where to get frion?
I need some to get my compresser running so my damned windows wont fog up when I turn the heat on
  #2 (permalink)
Old 01-21-2003, 07:40 AM
Yelrisheam Yelrisheam is offline
Yelrisheam is starting off with a positive reputation.
Where to get frion?
You can't get freon anymore over the counter. I believe the only way you can get it now is if you have at least a spec. 6 (automotive) A/C certification. If you need to get the compressor running, there's a low pressure switch that will shut the compressor down if the freon load is to low. This prevents the compressor from cycling and buring itself up. However, it is an extremely bad idea to run the compressor without the gas, for this same reason.
  #3 (permalink)
Old 01-21-2003, 11:44 AM
Where to get frion?
I can't just take it to Grease Monkey or something and have them dump it on in?
  #4 (permalink)
Old 01-22-2003, 08:19 AM
Paarrothead's Avatar
Paarrothead Paarrothead is offline
Paarrothead is starting off with a positive reputation.
Where to get frion?
What year is your truck?
Does it use R-12 or the newer stuff?
  #5 (permalink)
Old 01-27-2003, 02:13 PM
Mike G Mike G is offline
Mike G is starting off with a positive reputation.
Where to get frion?
The R-12 needs to be done by a facility. WalMart has a conversion kit for about $30 but I do not know if you will need additional cans of charge for the complete system. By '92 need to have the R-12 charge and rumor has it that runs $100. There is a place by I-25 and DTC that came recommended for the job but I can't recall the name now...
--Mike G
Tags
frion, r12
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
