1984 VIN decoder
Old 01-20-2003, 11:14 PM
ssvashon5's Avatar
ssvashon5
ssvashon5 is offline
Smile 1984 VIN decoder
1984 Could anyone direct me to a 1984' VIN ID site? I tried one web site, but the numbers didn't match well with mine. Isn't there a way to connect with Ford's own vin id center?
My VIN for my 84 F150 is - 1FTCF15H3EPB20079 -
Thanks,
Scott
Old 01-21-2003, 12:10 AM
83Steve's Avatar
83Steve
83Steve is offline
1984 VIN decoder
This is Ford's decoder, but it may not work on anything older than '95:
http://www.fleet.ford.com/maintenanc...ls/default.asp
You can call or e-mail them and they'll research your truck free & send you a build sheet. I have a link to more detailed instructions somewhere...
Old 01-21-2003, 07:49 PM
82F100SWB's Avatar
82F100SWB
82F100SWB is offline
1984 VIN decoder
I just happen to have a set of 84 manuals, so, here goes:
1FTCF15H3EPB20079
1FT: Manufacturer: Ford Moror Company, USA Make: Ford Type: Truck (complete vehicle)
C: Brake System: Hydraulic, GVWR Class: Class C GVWR Range: 4001-5000 LBS
F15: Line: F-Series Series: F150 Chassis Type: 4x2 Cab or Body Type: Pickup, Regular Cab Vehicle Type: Truck
H: Displacement: Litre: 6.1 CID: 370 Cylinders: 8 Fuel: Gas Manufacturer: Ford
This is not right, the 370 is a big truck engine, and, H is a heavy truck engine code, not a light.
3: Check Didgit
E: Model year 1984
P: Asssembly Plant: Twin Cities
B20079: Production Sequence Number
Evan
Old 01-21-2003, 08:42 PM
Chuck 6083's Avatar
Chuck 6083
Chuck 6083 is offline
Location: Where they take the census by counting the appliances on the front porch and multiplying by five
1984 VIN decoder
"I'm just your average 18 year old"
Don't let his age fool you.
Evan is top-shelf when it comes to truck knowledge and know-how.
Good job Evan.
Chuck
Old 01-21-2003, 10:13 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
1984 VIN decoder
Actually, the 370 was available in these trucks- it looks just like a 460, no external differences aside from a 2BBL carb. If you think you have a 460 2BBL, you have a 370 ( )
These are the most underpowered dog engines out there. In a big truck, I would rather have a 300-6. I drove a 12,900lb. F-600 a while back, loaded to gvw (actually 13,100lb!) and it would not do highway speed. Barely even do 45, and even then it would die on the hills. I mean about 25-26mph.
Old 01-21-2003, 10:40 PM
ssvashon5's Avatar
ssvashon5
Wink 1984 VIN decoder
Thanks to all for your replies and information. I've only been on this site for a few weeks but am grateful to all the help and good discussions.
I got my 84' last summer from someone who had it sitting for 4 years and only put 65 miles on it. The truck has 43,000 mls on it now and is original with a "351HO" stamp on the air cleaner.
The truck is in pretty good running order except for the nagging, what seems to be, carburator problems. Runs great once warm, but a challenge to get going in the cold. The carb seems to be getting too much fuel, as someone mentioned in an e-mail a week or so ago said. I did replace the electronic choke. I think it needs a new or re-built carb, but I've got to save up for that.
Long live Ford trucks!
Scott
Old 01-21-2003, 11:21 PM
82F100SWB's Avatar
82F100SWB
1984 VIN decoder
Ok, that explains it, the 351W HO was a mid year change, and my manuals were printed in Sept. 83......
As for the carb, stock on a 351W HO is a 600 FM 4180 Holley vac. secondary 4bbl.... I'd offer tuning advice, but, I've never had any luck with 'em... I replaced the one on my 460 with an Edelbrock....
Ford_Six: That's what I meant by it being a heavy truck engine, I should have written medium/heavy truck engine, as the F/B/C 600 are all medium duty. The 460 wasn't offered in heavy truck trim, only the 370 and 429, with both being avalable in 2bbl and 4bbl trim....
Chuck: Thanks, you give me more credit than I deserve, this is the kind of thing I do for something to do...
Evan
Old 01-23-2003, 11:05 PM
ssvashon5's Avatar
ssvashon5
1984 VIN decoder
82F100SWB,
Would it be hard to switch from the current/original Holley to another brand with my current intake manifold set up? Someone also said it may be better to start with a new carb and not a re-built one.
Thanks again for the info.
Scott
84 F-150 351W
Old 01-24-2003, 08:58 AM
82F100SWB's Avatar
82F100SWB
1984 VIN decoder
Any square bore 4bbl carb will bolt to the manifold. I went from Holley to Edelbrock on my 460, and, it only needed a new, longer fuel line, the carb came with the proper ball stud for the thottle, and hooked right up to the linkage without any modifications.
Evan
corndogia156
12-27-2022 05:37 PM
97vanswap
Large Truck
03-08-2020 03:43 PM
dnkensinger
39
12-28-2014 03:54 PM
blue_gill_slayer
1947 and Older Ford Trucks
07-13-2012 11:51 AM
trouble
08-17-2002 11:41 PM
Quick Reply: 1984 VIN decoder
