Warning, Fuel pressure gauge install went wrong
Okay here is what went wrong and a warning about the adapter used to install 1/8" gauge or sending unit. I take responsibility for not installing the adapter as I should but was surprised what happened.
The adapter has an o'ring on it so it shouldn't be tightened much at all. You should install the gauge or sending unit in the adapter first as it is 1/8" pipe thread and has to be tightened tight so to seal the threads then screw the adapter with o'ring into block and tighten just enough to compress the o'ring. Well I screwed the adapter into block first and then not thinking about overtightening it I proceeded to tightened the sending unit and within a 1/4 turn the threads stripped out of the block. After removing it I think the adapter is undersized because threads are not stripped completely but just the very top of threads in block.
adapter will not tighten now thinking of using JB weld to permanently install in block and pray the o'ring compresses enough so it doesn't leak or the JB Weld seals. What do you guys think?
Jharger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
07-21-2019 01:40 PM
Spktyr
13
11-16-2013 06:13 AM
cbrnflt
01-09-2007 11:32 PM
