04 150 4x4 power steering trouble
Old 02-25-2010, 06:19 PM
trx350first's Avatar
trx350first
trx350first is offline
Recently a friends 04 150 has been giving him trouble, it's been steering really hard, but not making any noise. Also he has no leaks.Now today the problem is gone and it's ok again, my personal expirience has been when it's the pump, it will make noise, usually when it's the rack, it will leak or make a different noise than the pump or both, i told him to have the ball joints checked. After working in a friends garage for 4 or 5 years we had a few fords that the ball joint seized up in the front, one day it was all right the next day when turning it would act just like a bad rack/pump. I would like to hear opinions or first hand knowledge about this topic.
Old 02-26-2010, 09:24 PM
ranair57's Avatar
ranair57
ranair57 is offline
I had the same problem and tracked it down to dry u-joints in the steering column.
I used a dental pick to lift the rubber seals on the u-joints and sprayed penetrant/lubricant into the joints and needle bearings, problem solved instantly for the cost of 8 shots of lubricant.
My truck steered very stiffly when the weather was below freezing and would steer normally when the temperature was warmer.
It was so stiff below 32F that it would not return to straight ahead when you let go of the wheel after a 90 degree turn.
Old 02-26-2010, 11:45 PM
Wilber15's Avatar
Wilber15
Wilber15 is offline
when it happens, rev the rpm's up. if the hard steer goes away, it's the pump....
Old 02-28-2010, 07:40 AM
Beefford's Avatar
Beefford
Beefford is offline
Had the same issue in my 04 - it was the steering shaft knuckle joint. Had the dealer put a new one in since it was only $100 but probably could have gotten away with lubricant as others have.
Old 03-01-2010, 06:43 PM
trx350first
Thanks for the info, i passed on the reponses to my friend. I hope thats what it turns out to be
Old 03-10-2010, 06:56 PM
trx350first
thanks again for the information, that's exactly what the problem was, this is how a forum should work
1999SuperD
09-27-2023 06:42 AM
bigsky22
2004 - 2008 F150
06-17-2012 03:11 PM
dcaprio
1999 to 2016 Super Duty
15
05-28-2009 12:32 AM
scstocks94f150
07-03-2008 05:50 AM
Hourang
01-03-2005 09:27 AM
Quick Reply: 04 150 4x4 power steering trouble
