04 150 4x4 power steering trouble - Ford Truck Enthusiasts Forums
Old 02-25-2010, 07:19 PM
trx350first trx350first is offline
trx350first is starting off with a positive reputation.
Recently a friends 04 150 has been giving him trouble, it's been steering really hard, but not making any noise. Also he has no leaks.Now today the problem is gone and it's ok again, my personal expirience has been when it's the pump, it will make noise, usually when it's the rack, it will leak or make a different noise than the pump or both, i told him to have the ball joints checked. After working in a friends garage for 4 or 5 years we had a few fords that the ball joint seized up in the front, one day it was all right the next day when turning it would act just like a bad rack/pump. I would like to hear opinions or first hand knowledge about this topic.
Old 02-26-2010, 10:24 PM
ranair57 ranair57 is offline
ranair57 is starting off with a positive reputation.
I had the same problem and tracked it down to dry u-joints in the steering column.
I used a dental pick to lift the rubber seals on the u-joints and sprayed penetrant/lubricant into the joints and needle bearings, problem solved instantly for the cost of 8 shots of lubricant.
My truck steered very stiffly when the weather was below freezing and would steer normally when the temperature was warmer.
It was so stiff below 32F that it would not return to straight ahead when you let go of the wheel after a 90 degree turn.
Old 02-27-2010, 12:45 AM
Wilber15 Wilber15 is offline
Wilber15 is starting off with a positive reputation.
when it happens, rev the rpm's up. if the hard steer goes away, it's the pump....
Old 02-28-2010, 08:40 AM
Beefford Beefford is offline
Beefford is starting off with a positive reputation.
Had the same issue in my 04 - it was the steering shaft knuckle joint. Had the dealer put a new one in since it was only $100 but probably could have gotten away with lubricant as others have.
Old 03-01-2010, 07:43 PM
Thanks for the info, i passed on the reponses to my friend. I hope thats what it turns out to be
Old 03-10-2010, 07:56 PM
thanks again for the information, that's exactly what the problem was, this is how a forum should work
Steering/Front end help bigsky22 2004 - 2008 F150 2 06-17-2012 04:11 PM
Hard Steering 1999SuperD 1999 - 2003 7.3L Power Stroke Diesel 9 04-14-2011 11:02 PM
Creaking in front end while turning when not moving dcaprio 1999 to 2016 Super Duty 15 05-28-2009 01:32 AM
94 F150 4X4 wandering steering new tires scstocks94f150 1987 - 1996 F150 & Larger F-Series Trucks 7 07-03-2008 06:50 AM
85 f250 4x4 - front end noise, ball joints? Hourang Brakes, Steering, Suspension, Tires, & Wheels 11 01-03-2005 10:27 AM
Tags
04, 2004, 2008, f150, ford, noise, power, problem, pump, stearing, steering, trouble, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
