33" tires fit on stock f150 4x4
Old 02-25-2010, 05:55 PM
93f250tn's Avatar
93f250tn
93f250tn is offline
will 33" tires fit on a stock 95 f150 ext. cab 4x4? or is 32" tires the biggest tires you can fit on there stock? I have 31" bf goodrichs on there now but i want alittle bigger tire and if 33"s will fit i have a buddy that can sell me a set dirt cheap. I do not want to spend any money on a leveling kit i just need to know whats the biggest size that will fit without any lift or fender trimming. Name:  truck13.jpg
Old 02-25-2010, 06:31 PM
Newenglandfordjunkie's Avatar
Newenglandfordjunkie is offline
Nice truck! I guess that is what mine was suppose to look like before the rust. I have heard that the 32 's will fit but to go to 33's you need a lift.
Old 02-25-2010, 08:20 PM
skyfox10's Avatar
skyfox10
skyfox10 is offline
Some guys run 33's and get away with it, but they tend to rub a little bit.
Old 02-25-2010, 09:22 PM
*2fords*'s Avatar
*2fords*
*2fords* is offline
My friend had 33s on his stock 85 and I'm pretty sure the wheel wells are the same size as our trucks. The tires did rub, but he had no problems wheeling his truck hard.
The only thing I can think may be a problem is the front bumper rubbing hard. I put tires that were about 2 sizes bigger than stock on my 93 F-250, and had to move the bumper out a bit (1/2") because the tires hit when turned either direction.
Old 02-25-2010, 10:06 PM
fordinlinesix's Avatar
fordinlinesix
fordinlinesix is offline
Yup, bumper needs trimmed or moved for 33s to fit the '92-96
Old 02-25-2010, 10:28 PM
cadillacmob's Avatar
cadillacmob
cadillacmob is offline
How hard is it to move the bumper out ?
Old 02-25-2010, 10:31 PM
BCHauler's Avatar
BCHauler
BCHauler is offline
Easy. You crawl underneath the front end and add washers between the bumper and the frame ends.
Old 02-25-2010, 10:42 PM
Farmboy46's Avatar
Farmboy46
Farmboy46 is offline
I had 33's on my 89 and the only problem was they rubbed the radius arms a bit when i would turn sharp, but thats no big deal. I say do it if there cheap thats why i did it.
Old 02-26-2010, 03:43 AM
travis jones's Avatar
travis jones
travis jones is offline
i had 33 super swampers on a 87 f150 no lift.. now i have 35' 15.50's on a 3 inch body lift
Old 02-26-2010, 03:50 PM
93f250tn's Avatar
93f250tn
93f250tn is offline
Anymore info on moving the bumper a tad would be great! right now with 31" bf goodrich all terrains i have 2 1/2" in the frontof the tire to the front bumper and 4" from the back of the tire to the fender. I would love to squeeze 33s and i dont mind it rubbing at all i just would like the bigger tires to make it look better and also would be good out on the construction job to have 12"s of surface vs 10"s of surface on these 31"s
Old 11-16-2012, 03:01 AM
A1C DiMaggio's Avatar
A1C DiMaggio
A1C DiMaggio is offline
I know im bringin back an old post, but i figured its better than posting the same question. i have a 1.5-2" leveling kit from bronco graveyard on order and a set of aftermarket wheels with 3.75" backspace. think that would fix the rubbing with 33x12.50?
Old 11-16-2012, 09:41 AM
Conanski's Avatar
Conanski
Conanski is offline
10" wheel with 3.75" backspacing? What wheel does it have now? Don't say stock there are 3 different versions.. 7", 7.5", and 8" all with 0 offset which equals 3.5", 3.75", and 4" backspacing.
Old 11-16-2012, 10:16 AM
minnesotafisherman's Avatar
minnesotafisherman
minnesotafisherman is offline
I think the only issue you will have with rubbing is the front bumper. I have 33x12.5x15's on mine with a 1.5" level in the front end, on 15x10 wheels with 4" backspacing. They only rubbed on the front bumper before I spaced it out and trimmed the lower lip on the bumper with a grinder.
Old 11-16-2012, 05:20 PM
A1C DiMaggio
they are the stock 15"x7.5" 5 hole. and the aftermarket wheels are pro comp steelies 15 X10" with 3.75
Old 11-18-2012, 02:39 AM
davytenn's Avatar
davytenn
davytenn is offline
MN fisherman,
I'm not actually home and won't be until mid DEC. How much can you move out the bumper, and how much did you take off the bumper by grinding? Does it matter if the 2WD F250 springs are standard or hvy duty?
I plan to go to 17x8 in rims, 4.5 backspace, and use LT285/70R17 tires. I have a 96 F150 4X4 ext cab. stock.
Your thoughts?
Quick Reply: 33" tires fit on stock f150 4x4
