33" tires fit on stock f150 4x4 - Ford Truck Enthusiasts Forums
Old 02-25-2010, 05:55 PM
93f250tn's Avatar
93f250tn 93f250tn is offline
93f250tn is starting off with a positive reputation.
will 33" tires fit on a stock 95 f150 ext. cab 4x4? or is 32" tires the biggest tires you can fit on there stock? I have 31" bf goodrichs on there now but i want alittle bigger tire and if 33"s will fit i have a buddy that can sell me a set dirt cheap. I do not want to spend any money on a leveling kit i just need to know whats the biggest size that will fit without any lift or fender trimming.
Old 02-25-2010, 06:31 PM
Newenglandfordjunkie's Avatar
Newenglandfordjunkie Newenglandfordjunkie is offline
Newenglandfordjunkie is gaining momentum as a positive member of FTE.Newenglandfordjunkie is gaining momentum as a positive member of FTE.
Nice truck! I guess that is what mine was suppose to look like before the rust. I have heard that the 32 's will fit but to go to 33's you need a lift.
Old 02-25-2010, 08:20 PM
skyfox10's Avatar
skyfox10 skyfox10 is offline
skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.
Some guys run 33's and get away with it, but they tend to rub a little bit.
Old 02-25-2010, 09:22 PM
*2fords* *2fords* is offline
*2fords* is gaining momentum as a positive member of FTE.
My friend had 33s on his stock 85 and I'm pretty sure the wheel wells are the same size as our trucks. The tires did rub, but he had no problems wheeling his truck hard.
The only thing I can think may be a problem is the front bumper rubbing hard. I put tires that were about 2 sizes bigger than stock on my 93 F-250, and had to move the bumper out a bit (1/2") because the tires hit when turned either direction.
Old 02-25-2010, 10:06 PM
fordinlinesix's Avatar
fordinlinesix fordinlinesix is offline
fordinlinesix is starting off with a positive reputation.
Yup, bumper needs trimmed or moved for 33s to fit the '92-96
Old 02-25-2010, 10:28 PM
cadillacmob's Avatar
cadillacmob cadillacmob is offline
cadillacmob is starting off with a positive reputation.
Quote:
How hard is it to move the bumper out ?
Old 02-25-2010, 10:31 PM
BCHauler's Avatar
BCHauler BCHauler is offline
BCHauler has a good reputation on FTE.BCHauler has a good reputation on FTE.
Easy. You crawl underneath the front end and add washers between the bumper and the frame ends.
Old 02-25-2010, 10:42 PM
Farmboy46's Avatar
Farmboy46 Farmboy46 is offline
Farmboy46 is starting off with a positive reputation.
I had 33's on my 89 and the only problem was they rubbed the radius arms a bit when i would turn sharp, but thats no big deal. I say do it if there cheap thats why i did it.
Old 02-26-2010, 03:43 AM
travis jones's Avatar
travis jones travis jones is offline
travis jones is starting off with a positive reputation.
i had 33 super swampers on a 87 f150 no lift.. now i have 35' 15.50's on a 3 inch body lift
Old 02-26-2010, 03:50 PM
93f250tn's Avatar
Anymore info on moving the bumper a tad would be great! right now with 31" bf goodrich all terrains i have 2 1/2" in the frontof the tire to the front bumper and 4" from the back of the tire to the fender. I would love to squeeze 33s and i dont mind it rubbing at all i just would like the bigger tires to make it look better and also would be good out on the construction job to have 12"s of surface vs 10"s of surface on these 31"s
Old 11-16-2012, 03:01 AM
A1C DiMaggio's Avatar
A1C DiMaggio A1C DiMaggio is offline
A1C DiMaggio is starting off with a positive reputation.
I know im bringin back an old post, but i figured its better than posting the same question. i have a 1.5-2" leveling kit from bronco graveyard on order and a set of aftermarket wheels with 3.75" backspace. think that would fix the rubbing with 33x12.50?
Old 11-16-2012, 09:41 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Quote:
10" wheel with 3.75" backspacing? What wheel does it have now? Don't say stock there are 3 different versions.. 7", 7.5", and 8" all with 0 offset which equals 3.5", 3.75", and 4" backspacing.
Old 11-16-2012, 10:16 AM
minnesotafisherman's Avatar
minnesotafisherman minnesotafisherman is offline
minnesotafisherman is starting off with a positive reputation.
I think the only issue you will have with rubbing is the front bumper. I have 33x12.5x15's on mine with a 1.5" level in the front end, on 15x10 wheels with 4" backspacing. They only rubbed on the front bumper before I spaced it out and trimmed the lower lip on the bumper with a grinder.
Old 11-16-2012, 05:20 PM
Quote:
they are the stock 15"x7.5" 5 hole. and the aftermarket wheels are pro comp steelies 15 X10" with 3.75
Old 11-18-2012, 02:39 AM
davytenn davytenn is offline
davytenn is starting off with a positive reputation.
MN fisherman,
I'm not actually home and won't be until mid DEC. How much can you move out the bumper, and how much did you take off the bumper by grinding? Does it matter if the 2WD F250 springs are standard or hvy duty?
I plan to go to 17x8 in rims, 4.5 backspace, and use LT285/70R17 tires. I have a 96 F150 4X4 ext cab. stock.
Your thoughts?
Tires: 31's or 33's LipRipper3006 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 01-03-2017 12:24 AM
33inch tires on a stock truck tyler.dunn94 1987 - 1996 F150 & Larger F-Series Trucks 5 01-14-2016 08:23 AM
1997 f150 4x4 biggest tire to fit stock height FordBoy2012 1997 - 2003 F150 8 09-13-2012 11:05 AM
Whats the Biggest Tire i can Fit 17" Rim 2000gpr 2004 - 2008 F150 2 04-09-2008 09:56 AM
Biggest wheel under 65 4x4? KRMFiero 1961 - 1966 F-100 & Larger F-Series Trucks 12 07-09-2002 12:00 PM
Tags
00, 1987, 33, 33s, 4wd, 4x4, 94, f150, f350, fit, fiton, size, stock, tires, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
