1995 5.8 correct firing order - Ford Truck Enthusiasts Forums
Old 02-25-2010, 06:37 PM
montgomery7 montgomery7 is offline
montgomery7 is starting off with a positive reputation.
this truck has the h in the vin. need to know the correct firing order, alot of places say this thing has two diffrent one's and i need the right one. we have replaced dist.,wires,plugs,coil,cap,rotor, and this thing is running rough checked the plug wires to make sure they were in the right place. now keep in mind before we started this major tune up the truck would start perfect and run for about 45 min and then when you tried to move it it would die and you couldn't start it back up. people said pickup coil or coil well it has new everthing on it now and still problems. any help on this thanks. timing is set 10 btdc
Old 02-25-2010, 08:23 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
There's only one order for the 5.8: 1-3-7-2-6-5-4-8. The distributor turns counter clock-wise and the cylinders are 1-4 front-back on passenger side, and 5-8 front to badk on the driver side.
Old 02-25-2010, 08:25 PM
Elderstarr's Avatar
Elderstarr Elderstarr is offline
Elderstarr is gaining momentum as a positive member of FTE.
Check my gallery for a pic...
Old 02-25-2010, 10:03 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
You removed the spout plug(to disable computer advance) before setting the timing correct?
Old 02-25-2010, 10:14 PM
yes pulled spout out and set timing, replaced plug and this is how it's running. one question though that 10 tdc is this after you replace the plug back in because one time we went 10 tdc and put the plug back in and it was on tdc, so we backed it up another 5 to 7 and had 10 tdc with plug in any feed back on this.
Old 02-25-2010, 10:23 PM
Conanski's Avatar
You want it at 10 degrees before TDC with the spout out and this should jump up to around 20 degrees or more when the spout is put back in.
390 ran rough, now not at all. smoky_diesel 1967 - 1972 F-100 & Larger F-Series Trucks 11 10-26-2016 12:26 PM
Firing order problem for my 4.9L inline 6 DarrellA Ford Inline Six, 200, 250, 4.9L / 300 9 08-11-2016 04:45 PM
No spark to plugs alexanselmo8 1987 - 1996 F150 & Larger F-Series Trucks 57 02-27-2016 09:20 PM
1986 f-150 no start Bear999 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 10-03-2015 10:23 AM
firing order ky94f250 1987 - 1996 F150 & Larger F-Series Trucks 14 05-22-2014 10:32 PM
Tags
1987, 1995, 30, 58, 95, cap, distributor, f150, f250, fire, firing, ford, order, plug, sequence, spark, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
