Cruise control servo for 92
Ok, now that i have the new engine in my 92. (after 300,000 on the old motor)
I want to get my cruise control back working again. Problem is, I believe my problem is in the servo. I replaced the horn pad already (found a really good used one,) and the control module under the dash.
Now for the strange part..... I can feel once I push the switch that it tries to take over, but it just cant. So, therein lies the search for a servo. Ford is a nogo, been discontinued!
So I can get a new one for an 89-91 at least. But does anyone know if it will interchange since the 92's were the last year for the vacuum controlled units?
Thanks
Thanks
on
I had the same problem with my truck and found a chaffed wire in the harness between the firewall and the cruise servo, and I couldn't see it until I unwraped that portion of the wire. I had already replace the amplifier thinking that was the problem, and the servo moved and held position when manifold vacuum was applied directly so I ruled that out and decided to check the wiring.
Ok, disconnected the vacuum line from the engine and hooked it to the Y connector that splits the vacuum on the backside of the servo. The cable moved, and stayed put. So will check the wiring tomorrow, and if nothing else replace the switches on the steering wheel. (Cheap insurance)
Thanks
Thanks
Nitro Blazer
06-03-2015 08:03 PM
