Fuel filter
Fuel filter
What kind of fuel filter does every one use ?
With the cap attached or not ?
It was time to change my oil and fuel filter so I got a Car Quest Fuel filter, it had the cap attached. I could not get it on without cross threading. So i just clean up my old one and it screwed back on without any trouble.
Also down in the fuel bowl I found a piece of wire with and electrical connection on one end and some kind round thing on a wire on the other. I took it out but have no idea what it is or where it cane from.
I use Wix oil filters.
I use the Racor/Motorcraft filter without the cap on the filter. I pefer the OEM filters and the separate cap. I've had better luck with the separate cap sealing better.
The wire is your fuel bowl heater. It's supposed to be in there but if you removed it, I wouldn't worry about putting it back in. Just unplug the electrical connection on the outside of your filter housing.
bubblegum
06-15-2011 03:57 PM
Crewcab Turbo
05-03-2011 07:21 PM
