Does the 7.3 have a timing chain and if so then how ofter are you supposed change it and where is it located or how does the crank keep timing with the cams?
The gears last long enough to re-use on rebuilds.
My new Ford long block, looking down into the cam gear, you could see the wear pattern on the cam gear.
Very definately a used gear, but it's made out of steel.
And thanks for the picture, that paints quite a nice picture of the strength of the timing. Now if only they'd do that on some gas engines! LOL then again why, I don't ever want to drive one again.
If something caused one of the gears to shear a few teeth off then yes. But I think you would have a hard time putting enough force on those gears to shear the teeth off. Maybe after eleventy bajillion miles they would wear enough to not mesh well anymore
So if I was a dummy and used starting fluid out of desperation, after someone ran it out of fuel, and now my truck cuts out at high rpm and makes a complete revolution before starting. What did i mess up.
