Radio removal question on E-450 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-24-2010, 01:36 PM
4dtruk 4dtruk is offline
4dtruk is starting off with a positive reputation.
I have an RV built on a 1999 E-450 chassis. I want to be able to play my iPod through the stock radio/CD player. The radio is a stock unit with a single CD player feature. Can anyone tell me how to remove the radio from the front so I can see if there are RCA jacks on the rear? There are 4 small holes, two on each side of the radio thay I think accept a special tool that will release the unit but I'm not sure and really don't want to tear anything up. Thanks
Old 02-24-2010, 01:50 PM
cworley250sd cworley250sd is offline
cworley250sd is starting off with a positive reputation.
There is a special tool, "ford radio removal tool" see link
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
I have heard of people bending clothes hanger and making one, I just bought my tool from autozone for about $.7.00
Old 04-29-2010, 01:43 PM
tk110 tk110 is offline
tk110 is starting off with a positive reputation.
Hi 4dtruk,
I also happen to have a 1999 E450 based Fleetwood and want to install a Pioneer AVIC-X920BT Nav unit in it.
Crutchfield is telling me that this Ford chassis is not a DIN 2 (japanese) mount and that the Pioneer will not fit even though the factory radio that I have is dimensionally a 2 DIN mounting.
Have you had any luck taking your unit out.
I do have the Removal tool like the previous poster mentions but the unit seems to be stuck and does not want to come out when i press the tools in and engage in the holes with a "click"
Old 04-29-2010, 04:32 PM
BPofMD's Avatar
BPofMD BPofMD is online now
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Be persistant.... push the tool in and then pull outward (towards the doors)just a hair...and pull out. It should come out. If it doesn't, someone has broken the bracket inside and you will have to start removing the dash to pull the old radio out.
It is soooo close to a double DIN that all it'll take is a very SMALL bit of filing to shave off JUST a little to get the double DIN radio in...... no sweat. Lots have done it.
Old 04-29-2010, 04:46 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
I bent a coat hanger to make 2 pieces just like the tool.
Worked fine for me.
Look at the pictures of how it interacts with the clips.. then just do it.
Old 04-29-2010, 08:05 PM
Persistence does pay off.
Its a crappy design because you have to get the tool to not go in too far as well as not far enough. Atleast on my E450 there is no hard stop for the tool. There is no reason there should not be. Anyway the radio is out.
Ford just has a single plug going to the radio in addition to the antenna.
(even though the radio has two connectors.)
The female plug on the cable side has a row of 16 on the bottom and 12 on the top with 2 pins on the end of the top row which are probably power and ground.
Whats the best place to get the pinout/wiring color code for all the signals?
Or better yet a harness to convert the cable plug to the Pioneer AVIC-X920BT plug or plugs?
Old 04-29-2010, 08:43 PM
Walmart, etc. sell a wiring harness that adapts to the plug.
Here are some color codes, check them out.
Wiring harnesses, car wiring harness, car stereo wires, metra, best harness, into car, into radio, harness, car stereo, factory radio, pioneer, kenwood, clarion, eclipse
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES LIGHT DUTY / 2005 / Audio
Radio 12v lt. green/purple + radio harness
Radio Ground black and black/lt. green - radio harness
Radio Ignition pink/black or lt. green/yellow + radio harness
Radio Illumination lt. blue/red (dimmer) + radio harness
Factory Amp Turn-on dk. green/purple + radio harness
Notes: This is the subwoofer amplifier turn on lead. The subwoofer and amp are in the driver side rear corner of the cabin. The subwoofer speaker wires are brown/orange (+), and red/black (-) at the radio harness.
Power Antenna N/A
LF Speaker +/- orange/lt. grn - lt. blue/wht +,- radio harness
RF Speaker +/- white/lt. grn - dk. green/org +,- radio harness
LR Speaker +/- gray/lt. blue - tan/yellow +,- radio harness
RR Speaker +/- orange/red - brown/pink +,- radio harness
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Old 04-30-2010, 12:15 PM
Thanks for the info.
I actually found:
eBay item #230407092961 harness to mate to factory plug and a DIN kit (which i may or may not use depending on how the Pioneer fits in the hole).
(it was less money than Wallmart or the other link u suggested.)
Any ideas where to tap signals for:
Speed Sense Signal
Parking Brake Signal
Reverse Gear Signal
These are obviously not present in the factory harness but would allow the pioneer to switch my backup camera in automatically and show a better position display on the Nav section.
I would think they are buried behind the dash somewhere?
Old 05-03-2010, 02:48 PM
No takers?
Old 05-22-2010, 06:09 PM
After not too much filing and grinding the opening,
I now have the Pioneer installed and working.
The harness method is sweet because I can very easily
go back to the factory radio if needed.
The parking brake input simply went to a limit switch
right be the brake foot pedal.
The only thing left is the
Speed Signal and
The Reverse Gear Inputs.
Having trouble finding schematics online.
Anyone have any suggestions?
Old 08-11-2013, 08:49 AM
shankerhook shankerhook is offline
shankerhook is starting off with a positive reputation.
Reverse Gear input
I spoke with a Pioneer support tech, reverse gear input wires into backup lights I'm also trying to find out where the speed limit input wire goes.
radio?cd player intruder1239 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 3 02-13-2012 09:50 AM
F 450 Radio issues Baney 6.7L Power Stroke Diesel 11 01-16-2012 10:09 PM
remove radio/cd player 2000 ford explorer berganbart Explorer, Sport Trac, Mountaineer & Aviator 2 11-28-2007 01:15 AM
CD Player Radio Problem 89broncoidlehigh 1999 - 2003 7.3L Power Stroke Diesel 27 02-18-2007 03:24 PM
Wrong CD player? balingwire 1997 - 2003 F150 2 01-16-2005 08:16 PM
Tags
1999, 2000, autozone, dash, disassembly, duty, e450, f450, ford, radio, removal, remove, super, tool, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
