1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
wheel Spacers
Old 08-10-2013, 05:39 AM
ransomwilliamson's Avatar
ransomwilliamson
ransomwilliamson is offline
wheel Spacers
Is it safe to use wheel spacers while pulling a 10K 5th wheel trailer?
Old 08-10-2013, 06:11 AM
senix's Avatar
senix
senix is online now
Received 1,413 Likes on 1,008 Posts
I think more info is needed. The spacers themselves should be no problem but how much of a spacer are you using?
What size tire on what truck?
If think with a bit more info that will help.
Old 08-10-2013, 08:20 AM
MC5C's Avatar
MC5C
MC5C is offline
All spacers are not alike. If you have 1" thick plain spacers and inadequate thread engagement on the lugs, then it is not safe. If you have a 1/4" plain spacer then it probably is safe. If you have a 2" thick wheel adaptor made of steel with it's own lugs, it probably is safe. As a rule, I go by the advice that wheel spacers are not safe until proven otherwise. "Proven" means an engineer did a load/strength analysis and it passed.
Brian
Old 08-11-2013, 03:44 AM
Uni-Lightning's Avatar
Uni-Lightning
Uni-Lightning is offline
I've ran 2" spacers on my 1 ton for at least 7 years. Zero problems with them. Proper lug torque and just drive.
justaboutbroke
16
02-17-2014 08:49 PM
cws10190
06-05-2012 08:44 AM
FORDorNothing12
1997 - 2003 F150
09-22-2010 05:32 AM
HunterFord
1997 - 2003 F150
05-08-2004 12:54 AM
Quick Reply: wheel Spacers
