1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Blower Fan Speed Issues
Old 02-24-2010, 12:22 PM
Marko44's Avatar
Marko44
Marko44 is offline
Hi everyone,
I have an '06 F-250 with the Automatic climate control system. A few days ago, the fan speeds appears to stay at a very low constant speed until you turn the fan controller to the top position. The fan speed display shows 7 horizontal hash marks represents the fan speed to the fan goes to high only when I set it to position 7. Everything else appears to work correctly, ie. it will switch from vent to defrost to feet only. Any ideas where to start with this?
Thanks
Old 02-24-2010, 12:59 PM
TEAM HARD's Avatar
TEAM HARD
TEAM HARD is offline
I may not understand you correctly, but it sounds like you need a new resistor. Are you saying that the fan only works on very low no matter what speed you adjust it to, with exception of the highest setting?
Old 02-24-2010, 01:52 PM
Marko44's Avatar
Marko44
Marko44 is offline
That is correct . . . the fan stays on low until you adjust the fan speed to the highest position at which point it blows high. Does that mean I need a new resistor?
In searching other threads, the resistor pack for an Automatic Climate Control system is:
# 4C2Z19A706AA
or Napa # BR-348
Does that sound right?
The location for the resistor found reading similar posts is:
And, it is the item located inside the housing, just to the left (drivers side) of the fan motor and slightly behind the AC dryer where electrical fittings are plug in. It is bolted in with 2 - 5/16" lug screws.
Old 02-24-2010, 02:20 PM
TEAM HARD's Avatar
TEAM HARD
Mine did the same thing, that sounds about right where mine was but I opted to let ford buy the part for me with some other small warranty stuff I had done so I'm of no help on the part number... but yes it was the resistor.
Old 02-24-2010, 02:48 PM
Marko44's Avatar
Marko44
Marko44 is offline
Thanks for the help Team Hard, I really appreciate it!
tm8620
1997 - 2003 F150
05-03-2016 02:17 PM
4_Econolines
01-17-2016 08:47 PM
jumperbob
12-15-2014 11:42 AM
warriorm
07-07-2012 08:23 PM
1Fordnatic
10-09-2010 04:44 PM
Quick Reply: Blower Fan Speed Issues
