Blower Fan Speed Issues - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-24-2010, 01:22 PM
Marko44 Marko44 is offline
Marko44 is starting off with a positive reputation.
Hi everyone,
I have an '06 F-250 with the Automatic climate control system. A few days ago, the fan speeds appears to stay at a very low constant speed until you turn the fan controller to the top position. The fan speed display shows 7 horizontal hash marks represents the fan speed to the fan goes to high only when I set it to position 7. Everything else appears to work correctly, ie. it will switch from vent to defrost to feet only. Any ideas where to start with this?
Thanks
Old 02-24-2010, 01:59 PM
TEAM HARD's Avatar
TEAM HARD TEAM HARD is offline
TEAM HARD is starting off with a positive reputation.
I may not understand you correctly, but it sounds like you need a new resistor. Are you saying that the fan only works on very low no matter what speed you adjust it to, with exception of the highest setting?
Old 02-24-2010, 02:52 PM
Quote:
That is correct . . . the fan stays on low until you adjust the fan speed to the highest position at which point it blows high. Does that mean I need a new resistor?
In searching other threads, the resistor pack for an Automatic Climate Control system is:
# 4C2Z19A706AA
or Napa # BR-348
Does that sound right?
The location for the resistor found reading similar posts is:
And, it is the item located inside the housing, just to the left (drivers side) of the fan motor and slightly behind the AC dryer where electrical fittings are plug in. It is bolted in with 2 - 5/16" lug screws.
Old 02-24-2010, 03:20 PM
TEAM HARD's Avatar
Mine did the same thing, that sounds about right where mine was but I opted to let ford buy the part for me with some other small warranty stuff I had done so I'm of no help on the part number... but yes it was the resistor.
Old 02-24-2010, 03:48 PM
Thanks for the help Team Hard, I really appreciate it!
fan control tm8620 1997 - 2003 F150 8 05-03-2016 03:17 PM
2013 E150 Rear AC fan won't shut off 4_Econolines 1968-2013 Full Size Vans 6 01-17-2016 09:47 PM
heater fan control working intermittently jumperbob Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 12-15-2014 12:42 PM
Climate control fan speed warriorm 1999 to 2016 Super Duty 5 07-07-2012 09:23 PM
efan monitor/switch wiring questions 1Fordnatic Cooling, Heating, Ventilation & A/C 5 10-09-2010 05:44 PM
Tags
1999, 2003, 2007, blower, f150, f250, f350, fan, ford, low, motor, resistor, speed, speeds, switch, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
