NH Bad Shops - Ford Truck Enthusiasts Forums
New Hampshire Chapter Join Chapter Leader: 7283-F250
NH Bad Shops
Old 02-24-2010, 09:31 AM
7283-F250's Avatar
7283-F250 7283-F250 is offline
7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all
NH Bad Shops
The not so up to par shops
Name:
Info:
Old 03-24-2010, 09:51 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
Nelson's Auto Repair
Reddington Street
Littleton, NH
Took my truck (48 F-1 with Volare suspension) there for an alignment and it was worse when I left than before they worked on it. Had to take it to a second shop for alignment.
Old 06-04-2010, 12:20 PM
7283-F250's Avatar
back to the top
Old 06-05-2010, 07:04 AM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
Quote:
Reddington Street
Littleton, NH
who worked on your truck??
White Mountian Transmission
Bethlehem,NH
went to have my trans tested for TC lock..went back to get truck to find trans out and taken a part...asked how come..he said needed to be rebuilt..i said how much...he said 3200 ...took him to court and lost..i had no witness and he had his wife....
In NH you don't need a estaminets to do work..you just give the OK by word of mouth....how is that fair??
with my custom tunes i had very hard shifts..had to put in a new valve body and pump to make it shift right..
Old 06-05-2010, 07:29 AM
Bethlehem,NH
In NH you don't need a estaminets to do work..you just give the OK....how is that fair??
I don't remember the guy's name that did the alignment at Nelson's but he worked on it for several hours and mumbled something about not being able to access the the upper A-arm bolts when I picked it up. I had gotten it close in my garage by using a small aftermarket alignment gauge I borrowed from a friend. It was driving pretty well but I wanted to be sure it as aligned properly since I had new tires on it. When I left Nelson's it was pulling very hard to one side. I should have just left the alignment where it was.
As far as White Mountain Transmission goes, I spoke with that same transmission shop in Bethlehem about a rebuilt TH350 for my truck when I first started building it in 2003. He quoted me $1000 for a rebuilt TH350. I never went back nor do I intend to deal with him ever. Found a rebuilt TH350 elsewhere for $350. He thinks he can charge people whatever he wants since he's the only guy in the area doing transmission work.
Do you know of anyone else in our area that rebuilds transmissions or does alignments on "special projects"?
Old 06-05-2010, 08:09 AM
state line auto on the left just across the bridge going into VT from lancaster...he quoted me $1500 for mine witch is a fair price...one person told me he does good work but i havent done anything with him my self nore heard of any one else say any thing..i try to work on my own rig's...i wish i would have heard of them before i ended up where i did...
Old 06-05-2010, 01:11 PM
I know what you mean...same here! I think if I need any more transmission work I'm just going to buy one off the internet. It may be cheaper in the long run and you don't have to deal with the local thieves...
Old 09-21-2010, 08:10 PM
7283-F250's Avatar
bump to top
Service (shop) manuals harald 1999 to 2016 Super Duty 17 12-19-2002 04:17 PM
Shop Manual MustangGT221 1987 - 1996 F150 & Larger F-Series Trucks 3 10-18-2002 03:26 PM
diesel shop thecoppercowboy Colorado Chapter 1 08-19-2002 12:17 AM
Shop manual GORSTEP 1999 to 2016 Super Duty 2 05-06-2002 04:28 PM
machine shop work dinosaurfan Performance & General Engine Building 2 02-04-2001 08:52 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
customizing, fords, nh, shops, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
