Egr restrictor plate
Hello
i am curious about doing the egr restrictor plate mod to my 93 f 150, i have used the search feature on here but didn't find much with a working picture. Besides i always get side tracked reading old posts anyway, so i thought if anybody had some old pictures and a write up that would be great
any body done this in a while? any side effects.
Pictures would be awesome if there are any.
if there is a thread on this, is it possible to make it a sticky or something that could be added to this forum so it could easily be found cause from what i have read it works.
thanks for any info
thanks for any info
No pictures, but try this !!
Even easier than the EGR restrictor plate would be (from an earlier post).....
"Go a hardware store and get a couple of 3/4" diameter fender washers, one with a 5/32" hole in it, and the other with a 7/32" hole in it.
Loosen the tube nut on the EGR valve and slide it back a little and insert the fender washer with the 7/32" hole in between the EGR valve and the flange for the EGR tube then snug it all back up.
This will allow EGR to flow (at a reduced rate) into the system and keep the CEL light off.
Test drive your truck a couple of days. If there's the slightest hint of a stumble or hesitation, do the above again and replace the washer with the 7/32" hole in it with the other washer that has the 5/32" hole in it.
In a sense.....it's an inline EGR Restrictor Plate !!!!
My total cost for this fix was 34 cents....and that was for 2 washers !!!! "
Much easier to install---1 nut*** EGR Tube Nut *** to loosen/tighten
Already fabricated
Hidden from the smog *****' visual inspection
That should get you going !!
Bob
Already fabricated
Bob
egr restrictor trick eliminated bog
Thanks for the post. The 3/4" fender washer with a 1/8" hole fits nicely between the pipe and the EGR valve. The washer edge was ground down a bit with a dremel tool to make it fit nicely.
End result: eliminated the excess EGR flow and all the off-idle bogging the truck has always had is gone. Gas mileage is up, and so is the off-idle, in-town, and highway speed performance. There is no spark knock or change in coolant temp after the mod. No MILs either before or after the mod.
I live in SE New Mexico at a low 3300' altitude. YMMV.
Cheers,
Mike M
'93 Bronco XLT, 5.8L
Cheers,
Mike M
92bronco4.9
04-21-2016 08:04 PM
fomocofool
18
02-03-2016 02:58 PM
mkirk68
03-12-2013 05:06 PM
Jermafenser
05-14-2007 09:57 PM
