Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 02-23-2010, 08:44 PM
04mudslinger 04mudslinger is offline
Garage is empty, add now
04mudslinger is starting off with a positive reputation.
5.4L Oil Pressure Sensor Location
I have a 2000 F150 5.4L 4x4. I understand the oil pressure sending unit is near the oil filter, correct? If so, does the oil filter need to be removed to get a hand back there to remove the sensor? I tried feeling around and couldn't reach it. If I have to take the filter off, how much oil will I lose on a cold engine? I am still 2000 miles away from a oil change.
I have the problem with the guage going to nothing and back up to normal in a matter of seconds. I don't have any loud noises, so I know I am getting oil.
Thanks!
  #2 (permalink)
Old 02-24-2010, 07:41 PM
chaser1602 chaser1602 is offline
chaser1602 is starting off with a positive reputation.
You wont lose any more oil than you do when you change the oil.Or just wait 2000 miles
  #3 (permalink)
Old 02-24-2010, 08:02 PM
vze2sgxa vze2sgxa is offline
vze2sgxa is starting off with a positive reputation.
Thanks!
I just did this replacement, I think it was a code 1248 or something like that pointing to sensor. The sensor is just above and slightly behind the filter mounting boss, you access it from behind the front diff, drivers side. Crawl under there and put a drain pan under it, you will catch about 1/2 to 1 full cup of fluid when you remove it. I had to buy the special oil sending unit socket from AdvanceAuto to get install it, none of my deep sockets fit over the part that connects to the pigtail. I was able to use a deep socket to remove the existing one - the old unit is smaller in size and socket fitting, the newer one is a redesign version, a little more stout, got it at Ford dealer. You will need a long extension and one swivel connection to get up and over the front diff to get at it. I used a long pick to pull on it and a long screw driver to gently lift up on the locking tab while removing the pigtail from sensor. The new OEM unit comes with threads coated with thread lock on it, but I added two turns of pipe tape just in case. Whole job takes about 1/2 hour, just take your time and don't cross-thread the new sensor, install it by hand then torque it down to spec. Turn the engine on to test, you won't have anymore problems.
__________________
2008 Escape Ltd 4X4/V-6, 40k as of Feb 2011. (I miss my 2000 Expy - it was a tank ... but it saved me in that accident.)
  #4 (permalink)
Old 02-25-2010, 07:41 AM
Thank you vze. That is the info I was looking for.
Tags
2000, 2004, 54, 54l, expedition, f150, ford, located, location, oil, pressure, sender, sending, sensor, size, socket, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
