Best oil to use on high mileage 95 f150? - Ford Truck Enthusiasts Forums
Old 02-23-2010, 09:44 PM
93f250tn's Avatar
93f250tn 93f250tn is offline
93f250tn is starting off with a positive reputation.
My buddy is changing the oil tommorow and kinda stuck between what oil to use... its a 95 f150 4x4 with the 351w and has 201k miles. Hes using the truck for work so hes doing it for me. I was planning on telling him to use mobil 1 5w30 full synthetic motor oil but i was thinking if i should switch to the high mileage stuff and if i should switch to 10w30. I have used the oil before in my 98 camaro Z28 that had a built LS1 pushing 420rwhp and loved it but im new to trucks and the 351w so im not excatly sure what this engine likes and dosent like Thanks for the input Also is it worth spending the money on the more expensive oil or should i just us conventional?
Old 02-23-2010, 10:12 PM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
worth every penny! I have a small SUV I run Mobil one 15000 mile protection in and go 10K between oil changes with 5K oil filter changes. I would definatly stay with at least 1 qt of synthetic as it give the oil better lubrication properties (ie out performs conventional oils all the way on a falinx (spell check) test. I run Mobil 1 full synthetic for trucks and SUV's haven't got brave enough to go 10K with the trucks yet... But easy to go 5K with plenty of oil life left. ALSO GET A WIX! they are the best oil filter you can get besides a Royal Purple oil filter which are only sold a Pep Boyz right now... ugh!!!! anyway spend the $5 extra bucks and your engine will love you for it... think about it like getting the Shlitz or Bud Light... which would you rather have... Personally if I was your engine I'd hope you buy the good stuff!
PS google the falinx test for synthetic oils... or Trucks had it on Power Block just the other day... Oh and mobile 1 is known to be one of the top runners for synthetic oil quality... I did weeks of research before i settled on mobil 1 synthetics... it's all I use now.
Old 02-23-2010, 10:18 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
I've been running Castrol high mileage in my 91 F150 [10w40] and my wifes 97 jeep cherokee [5w30] since we bought them and haven't had any trouble. I've used Castrol in all my vehicles and it seems to be a good oil, tho opinions seem to vary on it.
Ultimately it comes down to you, what you want to run vs. what can afford.
Old 02-23-2010, 10:20 PM
93f250tn's Avatar
Thanks for your advice! where can i find the WIX oil filter? and if i cant whats the second best to go with?
Old 02-23-2010, 10:52 PM
fishforlife2007's Avatar
fishforlife2007 fishforlife2007 is offline
fishforlife2007 is starting off with a positive reputation.
wix filter is the best for the money...i personally run amsoil 10w30, but if i didnt run that valvoline's maxlife is one of the best ones out rite now as far as high mileage oil is concerned. the maxlife comes in a semi, and full synthetic. i believe you can get a 5 qt. jug at wally world for bout 30 bucks. mobil 1 is a great oil when it comes down to it, however it is like a old technology when you compare it to some of the others. for you like i said above i would reccommend valvoline maxlife.
Old 02-23-2010, 11:30 PM
rmeyer001 rmeyer001 is offline
rmeyer001 is starting off with a positive reputation.
What about coke buildup and losing oil pressure?
OK, so what about this high mileage engine and running an oil that may inadvertently "clean up" the engine and thus drop your oil pressure. Example: Back in the early 90's I bought a high mileage 1977 F150 and ran a synthetic oil, thinking it was the best thing for this older truck, and it removed all the coke (ash) buildup that is common in high mileage engines, and it made my oil pressure drop, really drop, like to 10-20lbs. I ended up rebuilding and the mains were nice and smooth with no buildup, but that coke that was there and had made the gap much smaller, now the coke was gone and the gap was much larger and the oil pressure dropped. Think of a levee and a river. I am now in the same boat now with the truck I just bought has 180K. When I did the water pump, some bolts broke and I had to remove the timing chain cover... this let me see the front inside part of the oil pan and there was this black hard film on the inside of the oil pan. I want the best lubrication for my truck, but I don't want to remove buildup that is keeping my oil pressure up. Remember, I don't know the history of this truck. For you guys that have had them since low mileage, and properly maintained them, I think synthetic is fine, but my question is what about these high mileage ones that may have a build up?
Thanks,
Rick
Old 02-23-2010, 11:53 PM
93f250tn's Avatar
Quote:
Thanks,
Rick
Very good point rick! as far as my truck gos it was very well maintained... i am the second owner and the first was a ford manager that seems like he has kept it very well maintained but i dont want to take any chances. I could always go with the synthetic blend instead of the full on synthetic max life oil? BTW to give you an idea on how well kept the engine was i seafoamed the truck when i got it at 190k miles and there was very little carbon buildup because there wasnt very much white smoke at all which if it had alot of buildup it would have smoked for awhile and alot so im guessing based on that the engine was very well maintained but im not sure if that is a good thing to measure by?
Old 02-23-2010, 11:55 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Quote:
Go to NAPA, wix makes NAPA filters... Actually NAPA filters ARE WIX filters, just renumbered..
Old 02-24-2010, 12:20 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I don't think that full synthetic is necessary at all. What oil has been run in the truck for most of its life? If it has had Valvoline conventional all its life, I would switch the their Max Life. If it has had Pennzoil all its life, then I would go to Pennzoil high mileage. I wouldn't switch brands, but you could go to synthetic blend.
You don't need a Wix filter although Wix is good. Just get an FL1A Motorcraft, if you can't find a Wix.
By the way, I don't care if Amsoil is the best on the market. It is a pyramid scheme and I don not support that at all.
Old 02-24-2010, 05:43 AM
John SCB's Avatar
John SCB John SCB is offline
John SCB is starting off with a positive reputation.
Quote:
I agree 100%. Scheduled dino oil changes are fine if that's how the engine started at the factory. It's also more economical than going synthetic this late in life. I've heard more bad things about changing to syn later on than good things. At 169,000 miles my 5.8L has always been fine with conventional 10w/30...no complaints.
Old 02-24-2010, 10:22 AM
nstueve's Avatar
I'd just like to clearify my statements from above... A synthetic will improve your oils quality... the only reason I am running full synthetic is because i do 10K oil changes (crazy right... had the oil lab tested and it was still good for another 3-4K!) anyhow my old man uses Castrol GTX 10W30 and adds a quart of synthetic to his truck. gives a little extra protection and life to oil without streching it thin or to a consistancy that the engine isn't used to...
Ask the PO what he put in...
Old 02-24-2010, 10:06 PM
greyduk greyduk is offline
greyduk is starting off with a positive reputation.
Not to hijack the thread, but I have a 95 F-150 with a 351w also... and I'm getting a valve-tap type sound out of the passenger side of the engine. I haven't gotten to removing the valve cover yet to see if there's anything loose in there, as I'd rather get a more confident idea of what it is first. One shop recommended using a higher viscosity oil next oil change to see if that makes it go away at all... Last time was 10w30 and time before that was 5w40, sounds the same both ways.... Would the advice about full synthetic being unnecessary still apply here? It's got just under 130k miles on it.
Thanks!
Old 02-24-2010, 10:44 PM
nashaj's Avatar
nashaj nashaj is offline
nashaj is starting off with a positive reputation.
AMSOIL 0W30, read up on it. It's great stuff!
Old 02-25-2010, 12:06 AM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
OMG that made me laugh out loud!!!
Wow, some people think bud light is the "good stuff". Yikes!
If you haven't been using synthetic, don't switch to it at 200k. Your engine will start leaking everywhere. Use a high-quality conventional oil.
If your engine has under 50k or so then definitely switch to Mobil 1 - it's the best oil you can buy for your engine. But not at 200k.
Old 02-25-2010, 06:19 AM
Quote:
Thanks!
Before you tear into the engine, what oil filter is on it? If its a Fram, try replacing it with an FL1A.
1997, E-150, 4.6L oil question & PCV Rmasters3 1968-2013 Full Size Vans 5 12-03-2016 10:26 AM
Switching to synthetic oil on high miles SweetPete531 3.8 & 4.2L V6 6 09-23-2015 08:37 PM
Oil recommendation dbreckman 1997 - 2003 F150 2 07-28-2012 06:27 PM
Need some opinions on high mileage f150 93f250tn 1987 - 1996 F150 & Larger F-Series Trucks 6 10-01-2010 04:28 PM
who makes Cdn. Tire oil ? 351 power Oil & Lubrication 5 04-02-2004 01:49 PM
Tags
1996, 351w, conventional, dino, engines, f150, filter, ford, high, mileage, mileiage, oil, truck, trucks, weight, wix
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
