Replacement Driving Lights - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 02-23-2010, 08:26 PM
gvdcpa gvdcpa is offline
gvdcpa is starting off with a positive reputation.
I have a 2008 Expedition EL 4x4. Both of my driving lamps have cracked housings, with one holding water. The oem parts are close to $100 a piece. Has anyone found a better alternative?
Also, I replaced the headlights with H13ST Silverstar High Performance Lights. The lights are brighter and a whiter light. I think they look better and perform better.
Thanks for your input.
Old 02-24-2010, 10:17 AM
Harley Guy Harley Guy is offline
Harley Guy is starting off with a positive reputation.
Maybe eBay? Or Tasca Ford sells OEM parts at a nice discount...
Old 02-24-2010, 10:55 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Are you talking about the fog light housings or headlight housings?
Old 02-24-2010, 11:31 AM
The fog light housings.
Old 02-24-2010, 11:51 AM
berry1234's Avatar
Mine are cracked too and not from rocks hitting them. I have seen many complaints on the 07-09's about this. I think the bulb is very hot and the plastic can not handle the heat. Have it raining and cold water hot plastic do not mix. I think it will crack again unless replaced with a better material.
Old 02-24-2010, 11:59 AM
That was my thought as well. I have seen different housings, including the bulb, on the internet from $38 - $75. This is much lower than the price from my local dealership ($93). I just didn't know if anyone had better luck with a third party replacement.
Was planning on replacing fog light with the sylvania silverstar product, but if the lens is the problem, that might just make matters worse.
Old 02-24-2010, 12:24 PM
berry1234's Avatar
I didn't see any replacements with glass lenses. I would assume replacing it would only buy you a short time before it cracks again. My cracks are 1/2" and don't seem to effect the light output. I will just leave mine for now.
Old 02-24-2010, 12:26 PM
My cracks on the passenger side haven't affected the light, but the cracks on the driver side are large enough that the lamp is partially filled with water. This knocked out the driver side lamp.
I may try some third party housings and let everyone know how they do.
Old 02-24-2010, 01:24 PM
berry1234's Avatar
That is a problem. The prices vary greatly. I would try an aftermarket housing and see how it holds up.
2008 FORD EXPEDITION Fog Lights # FO2593221 @ GetAllParts.com
Old 03-02-2010, 10:47 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
If your lights are about the same size as the 2000 Navigator you should look at Northern Tool's web site. They have an excellent driving light with 100w bulbs for about $10.00 each. I put a pair on my Ranger and they really reach out there. I'm going to see if they will fit my Navigator soon.
Old 03-03-2010, 02:04 PM
Thanks for the additional option. I will check that out.
Old 03-04-2010, 12:09 AM
williamsplumbing williamsplumbing is offline
williamsplumbing is starting off with a positive reputation.
you fellas need to go wayyy back and check page 18, around mid August of 08. Berry1234, you were posting then, same subject. Maybe your answer is there.
Old 03-04-2010, 09:51 AM
I looked back and found this thread. I assume that is the one you were referencing. Thanks for the additional information. Looks like it has been a problem for Expeditions for a long time.
http://www.ford-trucks.com/forums/76...-cracking.html
Old 01-26-2011, 03:28 PM
fminperry fminperry is offline
fminperry is starting off with a positive reputation.
Thumbs up Replacement Bulbs and Lense Housing
Hey Everyone,
Found non OEM replacement bulbs and housing on EBay - $78. That's for two housings and two bulbs, plus $12 for shipping.
Not bad. There were some singles on EBay too.
Fred
Break in performance for new trucks Datavirtue 1999 to 2016 Super Duty 7 10-21-2016 11:08 AM
4 inch exhaust now no power Cochief 6.0L Power Stroke Diesel 28 04-12-2015 08:25 AM
428 PI vs. Performer RPM Purebeef FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 07-07-2014 05:09 PM
Engine Stutter ABS light erniek70 1999 to 2016 Super Duty 0 01-02-2014 08:17 AM
Superduty brake quandary... rockfiv0 Brakes, Steering, Suspension, Tires, & Wheels 3 06-18-2004 02:55 AM
Tags
2008, bulbs, cracked, driving, expedition, fog, ford, getallpartscom, light, lights, order, replacement, silverstar, sylvania, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
