Want to add heated mirrors, can it be done? - Ford Truck Enthusiasts Forums
Old 02-23-2010, 08:10 PM
balderman balderman is offline
balderman is starting off with a positive reputation.
I have a 99 F-250 with regular extending mirrors, is there any way to putt heated mirrors on and run the wiring for it? Is there a factory wiring kit that I can get? Has anyone done this?
Thanks in advance..
Brian
Old 02-23-2010, 08:28 PM
mike brez mike brez is offline
mike brez is starting off with a positive reputation.
I put heated turn signal mirrors on mine.
Old 02-23-2010, 08:32 PM
WideOpenFord's Avatar
WideOpenFord WideOpenFord is offline
WideOpenFord is starting off with a positive reputation.
Quote:
How did you do it?
Old 02-23-2010, 08:33 PM
indyF-350psd's Avatar
indyF-350psd indyF-350psd is offline
you can't fix stupid!
indyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to behold
sure can! just get the 05 and later mirrors with the turn signals and heat on them and they will bolt right up and then you just run the 4 wires for the ground the heat and the turn signals and running lights. there is a write up around here somewhere just do a search for 05 mirror conversion and you will find the link in the thread. you also might want to wire in a switch for the mirror heat so they are not on all the time....
Old 02-23-2010, 08:40 PM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
I did it with a pair of heated '02 mirrors off an Ex. I don't have the turn signals but I love the heat. I just wired the heat to the electric window switches in each door. Here's the write-up.
New Mirror installation
Old 02-23-2010, 08:53 PM
I wired the heat to a switch that is a key on power. I did not like the idea of them always on when the truck is keyed on.
Old 02-23-2010, 09:15 PM
Hit it!
One of these days, I will wire them to a defrost switch but they work for now.
Old 02-23-2010, 11:02 PM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
Well thanks to PonyBoyChris, he gave me a switch for the defroster from a 91 Exploder for my heated mirrors that I put on my 99. The switch has the timer built into it so I just wired it up and away I go.
Switch
Parking lights
Turn signal
Old 02-23-2010, 11:30 PM
jdw1's Avatar
jdw1 jdw1 is offline
jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.
BillyBob69, that truck needs cab lights, bad! Lol
Old 02-23-2010, 11:33 PM
BobbyDiesel71's Avatar
BobbyDiesel71 BobbyDiesel71 is offline
BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.
I am considering this swap/upgrade.
My 02 mirrors have no heat and I def prefer the turn signals in the mirrors vs w/o
Is the main issue the fact the heat always stays ON?
Old 02-24-2010, 07:34 AM
Quote:
I dont think it is a issue, If you were to get them on your truck from the factory thats how it would come. Personally I just did not like them on all the time considering the amount of time I use them.
Old 02-24-2010, 08:31 AM
Hit it!
Quote:
Switch
Parking lights
Turn signal
I was gonna ask you if you got that switch in yet. Glad you got it going. Obviously I haven't wired mine up yet. I think I'll put my Exploder switch on my F650 dash that I have - once I get that in... I really need to get some time for this stuff.
Old 02-24-2010, 08:34 AM
Hit it!
Like Mike said, the factory wiring has them on all the time. If you can find a defrost switch from a early to mid 90's Explorer, they have an internal timer that will power your mirrors on for 15 minutes. That's the way to go. All you have to do is run a wire from the doors, thru the wire loom in the door jam to underneath the dash to the switch.
Old 02-24-2010, 09:34 AM
BillyBob69's Avatar
Quote:
Well bring yer parts an c'mon on over! Now that I have a workshop at the new place...No ... wait... An INSULATED and HEATED workshop... Weather no longer stops me from playing. **I still get tickled about the workshop** hehe
Old 02-24-2010, 09:53 AM
Hit it!
That's a great offer. I'll have to invite myself over soon.
2015 F150 Adding heated/tow mirrors twstevens96 2015+ F150 0 03-15-2016 12:08 PM
2006 expedition wiring for heated mirrors mystang89 1997-2006 Expedition & Navigator 7 11-02-2015 01:30 PM
Heat and lights on 08 mirrors JF0623 Excursion - King of SUVs 3 06-09-2015 11:27 AM
2008+ mirror conversion - who's done it? the_auto_tech 6.0L Power Stroke Diesel 29 09-14-2013 06:53 AM
Aftermarket tow mirrors for 2008+ the Goat 1999 to 2016 Super Duty 10 09-15-2009 01:18 PM
Tags
2002, 2003, 350, add, added, f250, f350, f3tz18c621b, ford, heat, heated, homemade, mirror, mirrors, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
