Vent Window Removal
Dreamtruck, I have taken apart Mustang vent windows and also later 76 & 84 vent windows and they are almost identicle as the ones above. Basically, you have to replace the pivot screws and put springs and nut on the bottom. Than 3 or 4 screws hold it to door and a couple bolt inside the door. You might want to look in one of the parts catalogs (such as NPD) as they usually have a parts diagram. 66 to at least 97 should be almost the same as far as mounting.
Paul
Paul
bigf350sd
1947 and Older Ford Trucks
18
10-22-2022 05:28 AM
mikey1968
01-05-2019 09:13 AM
eric8
04-11-2017 12:30 PM
joedellcarter
17
03-19-2017 11:20 PM
