67 300 Econoline headers? - Ford Truck Enthusiasts Forums
Old 02-23-2010, 03:18 PM
timvreug timvreug is offline
timvreug is starting off with a positive reputation.
Has anyone seen or heard of putting headers on a 300 - 6 in a '67 Econo? I have a falcon super van that has a newer 300, and I'm in the process of MFI'ing it to an '89 4.9 system, only problem is that the 4.9 MFI exhaust won't fit in the doghouse, and I don't want to mess with blocking the old manifold riser.....
Hedman makes the 89300 headers for the truck, which I believe uses the same crossmember to mount the engine, but they have not had one in to fit check to see if it would work. I know it shouldn't work on the older econo's, as they mounted engine differently, but the '67 just might. Any help would be appreciated.
Old 02-24-2010, 07:35 AM
jschira's Avatar
jschira jschira is offline
jschira is gaining momentum as a positive member of FTE.
Clifford Performance/Research makes a ton of stuff for Ford 6 cylinders. Everyone that I know that has hopped up a 60s Ford 6 cylinder has used at least some Clifford products. I do not know how much of it will work on an E-100, but they can probably tell you.
Here is a link tho their catalog page for the Ford 300.
Clifford Performance: Ford 300 & 223
Old 02-24-2010, 04:08 PM
Thanks! I called Clifford and they confirmed it will work! I assume that will make all the truck headers to fit the '67 -300. So many have just never done it, as everyone wants to jam a V-8 in the hole!
Old 12-10-2011, 06:03 PM
marcgyver77 marcgyver77 is offline
marcgyver77 is starting off with a positive reputation.
Did you find headers to fit?
I have the same question and wanted to know if the Hedman headers from a 240 F100 would fit?
Old 12-10-2011, 08:21 PM
I think Clifford is the only one that will fit. I ordered the Hedman and they did not fit. they stuck out of the doghouse as well. I made a blocker for the old manifold, and went that way.
Old 12-10-2011, 10:17 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
The EFI manifolds that are split, will be an improvement....
Headers are useless on a stock engine.....The EFI mani's will give a definantly power boost....
Old 12-12-2011, 01:07 PM
Ruffinit's Avatar
Ruffinit Ruffinit is offline
Ruffinit is starting off with a positive reputation.
I used the Cliffords when I replaced the old 3:2 dual headers on my E100 p'up 170ci. The difference in torque and throttle response was quite evident. The 6:1 is a great way to go.
Though I haven't put headers on my '66 Falcon van, it has a 240 in it which is the same block as a 300 so you should be able to make that work. Give them a call they will KNOW. No guessing required.
1964 F100 4.9 swap whereiskrazydave 1961 - 1966 F-100 & Larger F-Series Trucks 10 10-28-2013 08:14 AM
MFI Manifold For a 1988 460 1988F250Beast!! Fuel Injection, Carburetion & Fuel System 2 02-04-2013 11:57 AM
1995 F700 7-0 MFI CEL diagnosis DogDoc Large Truck 0 10-14-2011 07:32 PM
65 Econo redline & doing 60mph Ratvan Clutch, Transmission, Differential, Axle & Transfer Case 1 03-04-2004 06:43 PM
stalling? John_M 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 06-17-1999 07:06 PM
Tags
1967, 300, 49mfi, 68l, cid, clifford, econoline, en, fit, ford, header, headers, linea, performance, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
