What size Allen to remove caliper for brake pad change on 2008 Ford Escape V6 2wd
allen wrench
Do no try to remove those the are factory set in lock tight , use the mounting bolts to remove from vehicle and make sure you grease those allen bolts good to insure calipers dont hang up . Also use ceramic brake pads they should last about 60K miles on these cars . also if you are new to the escape if you hear a whirring sound from the rear the back tires are suseptable to cupping I have owned a couple and the company I worked for did too actually very low matainence cars
largefries
09-07-2012 08:37 PM
deyomatic
07-12-2009 11:50 AM
