33" tires on stock truck/wheels - Page 2 - Ford Truck Enthusiasts Forums
Old 02-23-2010, 10:50 AM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel has a good reputation on FTE.Blue Rebel has a good reputation on FTE.
Another cheaper option is to go with a body lift, either 2 or 3" will lift the truck enough to fit 33s nicely.
I wouldnt worry about putting 12.5s on the stock rims, I have a friend whos got 33/12.5 on the stock rims. heres a pic of his truck
Not the best pic, but this truck has a 4" suspension lift and 33/12.5 on stock 93 f150 rims
Old 02-24-2010, 12:52 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
15x10 is really only suitable for 12.50 width, but a 12.50 will fit stock rims just fine. For 11.50 and 8 inch wide rim is a better fit. For 10.50 7.5-8 inches wide is a good fit.
Stay away from body lifts.
Old 02-24-2010, 02:14 AM
nick8403 nick8403 is offline
nick8403 is starting off with a positive reputation.
jsut run some 32s or do 33s jsut run a lower tire pressure
Old 02-24-2010, 02:18 AM
Quote:
Originally Posted by fulldraw93 View Post
Well thanks guys. It sounds like I better either go with the 31x10.5R15 or the 33x10.5R15 with a 4" lift. Im just not sure if I have the money for the lift. The 30x9.5R15 's that are on the truck now drive me nuts because they look so tiny. And its not all just for looks I go offroading just about every weekend, so the larger tires would be nice. Im not sure if the 31" 's would be much of a difference at all (looks or performance).
On a 4wd you can run 32 11.50 and it looks sweet!
Old 02-24-2010, 02:19 AM
Quote:
Whats the lower pressure going to do? Its just going to increase fuel consumption and tire wear as well as increase the chance of having the tire come off the bead.
Old 02-24-2010, 09:34 AM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
I'm thinkin he was refuring to running a 33 on stock wheel at lower pressure so the whole tread hits the ground.
If you want some 33sn get some 15x10s with 4 inches of backspacing, and trim your front bumper a bit. I had my 33s on before I put a 1.25 spacer in the front...
Old 02-24-2010, 08:06 PM
fulldraw93 fulldraw93 is offline
fulldraw93 is starting off with a positive reputation.
I think 32"s would be perfect for me since i wouldnt have to worry so much about rubbing issues, regearing, etc. Its just that on all the charts ive seen, they say that a 11.5" wide tire is too large for a 7.5" wide rim.
Old 02-24-2010, 08:28 PM
Hitokori's Avatar
Hitokori Hitokori is offline
Hitokori is gaining momentum as a positive member of FTE.
what rims do u have?
i have the factory rims on mine and they are 15x8's
Old 02-24-2010, 09:08 PM
fordman1090 fordman1090 is offline
fordman1090 is starting off with a positive reputation.
You can lift the front pretty easy, a few people run f350 coils which gains you about 1.5-2in, Or go to a junk yard and get the coil spring seats from a 2wd. They are about 1.5in taller.
Im running the f350 coils and 33's look really nice. and so far i have no rubbing issues, but im running a different setup.
Old 02-24-2010, 10:55 PM
the door jam sticker says they are 15"x7.5"
Old 02-24-2010, 10:58 PM
hav24wheel's Avatar
Different wheels are cheap if u want wider tires than a 10.50.
Old 02-25-2010, 12:52 AM
Hitokori's Avatar
do they look like these or what? i have these and i thaught about painding them black lol
  #28
Old 02-25-2010, 06:09 AM
I like those wheels the way they are or restore them.
  #29
Old 03-17-2010, 08:08 PM
|WYG|SS's Avatar
|WYG|SS |WYG|SS is offline
|WYG|SS is starting off with a positive reputation.
i am just reading this and currious on my 93 f150 i replaced the rear leafs with 1989 f250 leafs and i have them on their with out the lift block and i want to raise the front end cause it sits lower than the rear and i want to add the lift blocks on the leaf springs what size lift would i need for the front? 2in,3in, or 4 in? i want to add a little lift to the truck. i have 31 bfg ats on their now. want to get bigger tires soon. not trying to thread jack.
  #30
Old 03-17-2010, 11:22 PM
93f250tn's Avatar
93f250tn 93f250tn is offline
93f250tn is starting off with a positive reputation.
Hey fulldraw i have the same truck as you and i actually have 31 bfg all terrains on it now and they just look to small im currently looking for a set of 33s to put on and mine is completly stock so ill probably have to space the bumper or trim it so they dont rub. You will be much happier with 33s but intell you put a leveling kit on it dont flex the front to much or like previosly stated you may be looking for new fenders lol
31x10.5r15 Tires stydel311 1987 - 1996 F150 & Larger F-Series Trucks 10 11-18-2014 09:59 PM
Tire size question 91chevywt 1987 - 1996 F150 & Larger F-Series Trucks 9 10-31-2010 08:31 PM
stock '94 & 33x11.5 tires? RhinoScores 1978 - 1996 Big Bronco 16 02-02-2007 11:35 AM
Tires? 31x10.5R15 or 33x10.5R15 Tripleplay 1978 - 1996 Big Bronco 10 11-10-2006 08:27 PM
Tire Size Question 92_FlareSide Brakes, Steering, Suspension, Tires, & Wheels 1 09-05-2006 11:02 PM
Tags
15x8, 1995, 33, 33s, 33x12, 96, f150, f250, fit, ford, inch, rims, stock, tires, truck, vintage, wheels, xterain
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
