Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 02-22-2010, 02:17 PM
Klute Klute is offline
Garage is empty, add now
Klute is starting off with a positive reputation.
Question No Sirius radio, no DVD system
I have a 2008 Ford Expedition EB with the factory installed Sirius satellite and Rear Entertainment system. All systems were working fine. The menu on my radio said DVD Menu (meaning the movie had finished) so I decided to change out the movie for my granddaughter. The disc ejected and I put another in and nothing! It will eject and load and the lights will come on while doing so then again...nothing. There is no FORD screen saver on it at anytime now either. Then I tried to go to my satellite radio and no satellite. I do have functioning AM-FM-CD. When I hit Aux it goes to line-in, Sat1, Sat2, Sat3......no longer shows DVD function at all. I checked the fuses under the dash (passenger side) and also under the hood. All seem to be fine............HELP PLEASE. Did I hit something to lock it all out? Is there a reset/reboot button I can hit. Can't really afford to take it to the Ford dealership for them to fudge with for 4-5 hours. Any suggestions? Thanks...
  #2 (permalink)
Old 02-22-2010, 03:19 PM
function12's Avatar
function12 function12 is offline
function12 is starting off with a positive reputation.
Try disconnecting the battery.
__________________
See ya,
Eric
  #3 (permalink)
Old 02-22-2010, 03:52 PM
Thanks Eric, will try that......but will I create any other probs by doing that? I know I'll lose my clock and preset stations but will that be the worse? Also, do I need to undo both cables or will just one work? Thanks, Linda
  #4 (permalink)
Old 02-22-2010, 06:13 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Just the positive. No other problems.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #5 (permalink)
Old 02-22-2010, 09:27 PM
gddyup's Avatar
gddyup gddyup is offline
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
Quote:
No. Anytime you remove battery cables, it is always positive first, negative last when connecting the battery. Disconnecting the battery it is always negative first, positive last. When done in this manner you lessen the probability of having sparks when connecting or disconnecting your battery cables.
Ever seen a battery explode? I have. Not a pretty sight. Connecting your battery cables in a way that creates spark is enough to blow one up right in your face. I've seen it happen. The same thing goes when connecting jumper cables. To "erase" any memory functions, the only thing you need to do is remove the negative cable for a few minutes.
  #6 (permalink)
Old 02-23-2010, 09:29 AM
function12's Avatar
Removed. I read your responce wrong.
__________________
See ya,
Eric
  #7 (permalink)
Old 02-23-2010, 10:34 AM
berry1234's Avatar
Thanks for the tip. I never knew which cable came off first.
__________________
  #8 (permalink)
Old 02-23-2010, 11:58 AM
I think he just threw in too many words before his intended meaning......"it is always positive first, negative last when connecting the battery. Disconnecting the battery it is always negative first, positive last." So, he is correct, just a little mixed up wording, lol. negative-positive then positive-negative. Thanks for all the help, believe it or not a little 15 amp fuse #3 solved the problem and we are back in business. Thanks all.....Linda
Tags
2010, dvd, expedition, f150, factory, ford, hard, radio, reset, satellite, sirius, stereo, system, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
