1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Mud Terrain Tire Advise...
Old 02-21-2010, 11:45 PM
motor-man's Avatar
motor-man
motor-man is offline
Hey guys, I'm looking for either a 35x13.5x20 or 37x13.5x20 M/T tire. What do you guys recommend? I had a set of Mickey Thompson Baja MTZs 33x12.5x16 on my old f-150 and liked them. If nothing else really appeals to me I may go with this same tire again. I like the looks of the Pro Comp Xtreme M/Ts, however the widest tire they have is a 12.5'', according to there website...What do you guys recommend?
Thanks.
Old 02-22-2010, 12:45 AM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
Thanks.
BFG M/Ts are the best mud tires IMO.
They get my 2wd truck though all kinds of sh...... I mean slop.
Old 02-22-2010, 12:54 AM
redford's Avatar
redford
redford is offline
Received 1,562 Likes on 910 Posts
Are you going for looks or performance?
Old 02-22-2010, 02:12 AM
wallz's Avatar
wallz
wallz is offline
I like the look of the new KM2's from BFG. The only reason I ended up with the procomp Xtrns is because the km2 were not out yet and would not be for a few months and I needed tires asap. They will more than likely be my next tires, just don't know if they carry the widder tires.
Old 02-22-2010, 09:04 AM
motor-man's Avatar
motor-man
Alright thanks. However i don't believe these come in 13.5''...
Both. I want a tire that performs, but its gotta look good too!
Okay thanks, but your right, I believe their widest is 12.5''.
I really like the Toyo Open country M/Ts, however my shop doesn't have the right to sell them. I may end up getting those tires somewhere else, however I wan't to give my shop the business, we'll see.
Old 02-22-2010, 09:32 AM
Ace!'s Avatar
Ace!
Ace! is offline
They offer a 36x13.5x18 or 35.5x13x20, so pretty close. Do you want a D or E load range? It doesn't look like you have 20" wheels based on the photo, but maybe...
Also, they do have 14.5" tires if you want to go up another inch in height.
Old 02-22-2010, 10:34 AM
DieselBeast01's Avatar
DieselBeast01
DieselBeast01 is offline
Got Nitto Mud Grapplers on mine. I really like them. I have had all sort of mud terrains and none of the other seem to last like the Nitto's have.
Old 02-22-2010, 10:45 AM
rotun's Avatar
rotun
rotun is offline
Reads ***** rules!
What size lift are you planning for the 37's? Here's a pic of the front of my F350 with a DR 7" + 1" TEI, 17" wheels with the Toyo M/T. I have just over 30,000 miles on them now of mixed highway, around town and quite a bit of trail use and will probably get another 15 to 20k out of them. If you're doing this for off- road reasons I don't recommend 20" wheels as you will not get as much flotation out of them when airing down for added traction, not to mention the shorter sidewall height has it's cons. The 20's will also give a harsher ride in addition to the ride of a lifted truck. 18" or 17" might get you a larger variety of tires to choose from.
Also a good point was brought up about load range....Toyo's are rated at 4300 or 4200 lbs. which also gives reason to their longevity.
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=ofc09021.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/ofc09021.jpg" border="0" alt="Photobucket"></a>
Old 02-22-2010, 12:12 PM
motor-man's Avatar
motor-man
I'm not sure if I want D or E. As of right now I do not do any kind of towing that would require an E rated, however I don't want my "D rated" tires holding me back from towing something. Yes I do have 18'' rims, however I will be getting new rims as well.
Thanks, I'll look into these.
I will be running a 6'' lift, so I'm still deciding between 35s and 37s. I am not a serious off-roader, mostly just out back of the house in our 40 acres messin around once in a while. I also ocasionally do some off-roading in some local pits. I think I am willing to sacrifice some off-road traction for the looks of the 20''. I know this is a dumb question but a 4300lbs rating... Is this alot or no?
Old 02-22-2010, 01:09 PM
Ace!'s Avatar
Ace!
Ace! is offline
4300 is A LOT.
The size of the tire overall doesn't change with different sized wheels, so since a 36x13.5x18 is available, why do you want the 20" wheels, just looks? Seems the 36x13.5 is exactly what you want (35 - 37" tires)???
Old 02-22-2010, 01:35 PM
06silvercrew's Avatar
06silvercrew
06silvercrew is offline
I have had the best luck with the Mickey MTZ's, pricey yes but I have over 25K miles on my current 36-15.50-20 and they still have every bit of half tread.
As for the post about the mud grapplers, that has got to be, the WORST lasting tire I have ever had, aside from a bogger, on the street. 20K miles MAX and they are shot, all 3 sets of them that i had.
Old 02-22-2010, 01:42 PM
FI460's Avatar
FI460
FI460 is offline
I love my toyo mt's. They take me a lot of places just in 2wd and just about anywhere in 4wd. They were used when I got them so I can't speak about the mileage. I have some friends who've got around 50k+ out of theirs. A thing to consider is the toyos from my experience don't like cornering. My dad had a set and they only lasted about 20k and were shot. I attribute this to the fact that he lives on a river road and figured they dont like cornering that weight at 55 mph.
Old 02-23-2010, 10:50 AM
motor-man's Avatar
motor-man
4300 is A LOT.
Yes I want the 20'' for looks. A 36'' tire may be a good option for me...
36x15.5x20 whoa! Themz some wiiide tires. I may just end up going with the MTZs agian...
Old 02-23-2010, 11:05 AM
rotun's Avatar
rotun
rotun is offline
Reads ***** rules!
Here is specs on Toyo M/T
File Type: pdf
Old 02-23-2010, 03:37 PM
Mark _G's Avatar
Mark _G
Mark _G is offline
I have the 325/65 18s MT Baja MTZ on my F350. Great tires.
Quick Reply: Mud Terrain Tire Advise...
