Aux Engine Oil Cooler? - Ford Truck Enthusiasts Forums
Old 02-21-2010, 08:40 PM
agp23109's Avatar
agp23109 agp23109 is offline
agp23109 is starting off with a positive reputation.
I saw a post about some asking about rebuilding their oil cooler. It got me thinking is anyone running an aux engine oil cooler? If so how did you do it? Since the engine uses oil as a cooling agent I figured it wouldn't hurt to have an aux cooler. I searched the forum but did not find anything.
Old 02-21-2010, 09:17 PM
87crewdually's Avatar
87crewdually 87crewdually is online now
87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.
It's funny you should ask. While skimming through the latest JEGS catalog, i saw an oil cooler/filter setup that is actually 6.9/7.3 IDI specific. I couldn't believe it. It gives you remote dual filters, cooler, lines, fittings, and adapter. It's NOT everyday you see something specific like this in a catalog like this. Check It Out: 771-40110 - JEGS High Performance
Old 02-21-2010, 10:58 PM
WarOzz's Avatar
WarOzz WarOzz is offline
WarOzz is gaining momentum as a positive member of FTE.
That's one nice looking kit! If I end up doing a lot of heavy hauling with mine then I might consider this kit. As a daily driver it's probably overkill.
Old 02-21-2010, 11:07 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
Thats a nice looking kit, now if only there was a way to bypass the factory oil cooler to eliminate all the headaches it causes.
Old 02-21-2010, 11:11 PM
stevilknevil's Avatar
stevilknevil stevilknevil is offline
stevilknevil is starting off with a positive reputation.
Quote:
i've been wondering about that too
Old 02-21-2010, 11:14 PM
For o-rings having to be replaced after over 20 years of service i don't see any reason to. Plus that oil-coolant cooler is way more effecient than any oil-air cooler. Just that cooler in the kit alone wouldn't be enough to cool the oil on it's own without the stock oil-coolant cooler doing the grunt of the work.
Old 02-21-2010, 11:18 PM
Quote:
You are probably right, but looking at it and reading all the wonderful posts about it really make me fear having to service the darn thing.
Old 02-21-2010, 11:23 PM
It's nothing. Don't sweat it. If it worries you that much gather the parts now and doit the next time your sittin around looking for something to do. Plenty of petroleum jelly on the rings and it goes right together while keeping everything square. When you reinstall don't use any silicone sealent on the gaskets but DO use thread sealent on the bolts because they go into the water jacket. Cake job.
Old 02-21-2010, 11:32 PM
are the elements still real expensive?
Old 02-22-2010, 12:42 AM
starmilt starmilt is offline
starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.
Headaches they usually out last two gas engines, kinda like return lines they will usually last as long as a lot of gas engines,
Old 02-22-2010, 09:32 PM
kenpobuck's Avatar
kenpobuck kenpobuck is offline
kenpobuck is gaining momentum as a positive member of FTE.kenpobuck is gaining momentum as a positive member of FTE.
Mine is still going strong and I even baked it lol! When I was getting this engine ready for the swap I pulled the cooler and cleaned it then put on high temp grill paint. You have to get it up to 450 degrees to cure so I put it in the oven and baked it. Needless to say my baby didn't think it was all tyhat funny as it let a strange smell in the oven lol! That was the first and last time I ever cleaned an oven!
Old 02-22-2010, 10:53 PM
tlk50's Avatar
tlk50 tlk50 is offline
tlk50 is gaining momentum as a positive member of FTE.
Yep Kenpobuck, mine really really really hated me washing my carb clean dunked carburetor parts in the dishwasher. The red hair became flaming red and the loving-affection thermometer dropped to 300 below in an instant. I though every freckle on her face was going to explode. Sorta like a diesel on gasoline, a total berserk runaway. Needless to say I only did it once.
Old 06-22-2013, 05:00 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
link no longer works.anyone know the brand and part number of the kit?
crewdually,you abandoned us for a 6.oh no! the blasphemy.
did you keep the old idi rig around?
hmm.i wonder if they make those remote oil filter/cooler adapters with a temp sender port too.maybe it doesn't matter much,but one would think the best place to grab oil temps would be right down low there.
Old 06-22-2013, 05:38 PM
You caught me! I still have the 4x4 project truck but did sell the crew dually. As soon as a friend found out about the 6.0, he wanted the 6.9. I didn't blame him and I miss it dearly but I do have visitation & buy-back rights. The first week of owning the newer truck I did necessary known issues such as dummy plugs and HPOP. Been great making trips to Florida, Tennessee, Pa, all with the 5er in tow. I'm always looking for a clean 87 to pickup for a project, we will see. I still check in but rarely. Just no time.
Hope all is well with all that I communicated with during my era.
As far as a temp sensor port, nothing a drill bit and 1/8" NPT tap can't fix.
Old 06-22-2013, 05:42 PM
Aux Engine Oil cooler suggestions Gatordog 1999 - 2003 7.3L Power Stroke Diesel 6 10-21-2015 11:06 AM
4R70W Oil Cooler Lines; Which is in and which is out?? Trigger200 1997 - 2003 F150 5 06-07-2009 06:27 PM
Tranmission Cooler ggirten 1999 - 2003 7.3L Power Stroke Diesel 6 09-27-2007 04:45 PM
5R110 Torqueshift Caution!! Fredvon4 1999 to 2016 Super Duty 2 02-11-2005 07:45 AM
Routing Trans Fluid Through Aux Cooler? 4byford Clutch, Transmission, Differential, Axle & Transfer Case 13 08-11-2004 10:56 PM
Tags
460, 73, 73l, aux, cooler, cooling, engine, ford, idi, oil, remote, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
