Speedometer Issues VSS or Dash cluster ?
Early 99' F-350 S/D 7.3 Automatic with O/D . 200k miles. Speedo isnt working at all . My tach works fine . I still have use of my cruise control. Nothing lit up on my dash and it isnt throwing any codes via obd 2 . Ive checked other posts everyone is saying they have some other symptom to go along with their speedo being out. I have no other issue but the Speedo could it still be the VSS ? Thanks for everyones help .
No the overdrive light is not flashing . The scanner is a innova/bluepoint my buddy bought it off the snapon truck at his work. It picked up the cam position sensor code when that went bad on me a few weeks ago but that was it . Had the dealer fix that recall and they didnt mention anything about the Speedometer and i didnt really want them messing with anything especially if they were going to charge me for their damage.
Wires look fine everything is hooked up . Could the Speedo portion of my cluster be messed up ? I took the cluster out everything is plugged in properly traced the wires back no splits in the wires . I really like knowing how fast im going especially on Florida Highways speed limit is 70 mph in allot of spots . You all know what that means.
Fusion7.3
1999 to 2016 Super Duty
05-29-2014 02:35 PM
