4R100 Harsh 1-2 - Ford Truck Enthusiasts Forums
4R100 Harsh 1-2
Old 02-21-2010, 06:21 PM
KooLaid KooLaid is offline
KooLaid is starting off with a positive reputation.
4R100 Harsh 1-2
I've read through more threads than I can count but never found a definite answer on the all too common hard/harsh 1-2 shift on a 4R100.
Pretty much my transmissions works wonderfully in my basically stock 84k mile 99 V10 F250 except for the 1-2 shift. When cold, it shifts ok first thing in the morning for a minute or two. Then when everything is warmed up, 1-2 is "neck snapping" and ONLY 1-2. Everything else is fine.
I've read about a broken spring, particularly the accumulator spring. Also noticed something about TPS and shift solenoid.
So I've got a few questions.
1) Where is a good place to source parts to rebuild my valve body? Particularly swapping out the springs.
2) Is there a guide to rebuilding my valve body?
3) Where can I find an electronic copy of a service manual for my 99 V10 Auto 4x4 F250?
I've decided to also change out the tranny fluid to synthetic and filter when I do.
I do NOT tow, so I don't need a beastly transmission but improvement is always a plus. I just need my transmission to work properly. Future (6 months) plans include a small lift 4" and 35" tires max. No major towing plans.
Guide the way gentlemen! I'm all ears!
Old 02-22-2010, 08:24 PM
jk080's Avatar
jk080 jk080 is offline
Gear Head
jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.
Most of the time I have one of these that has a very hard 1-2 shift and no codes, the problem is in the accumulators part of the valve body. There is a little valve behind the 1-2 accumulator that sticks. I would recommend installing a Trans-go shift kit. The kit will give you a steel valve that replaces the stock aluminum one, it also has the springs for all the other accumulators, I use this kit on all E40Ds and 4R100s I build, it makes these transmissions shift great it will have very detailed instructions to answer all your concerns and a phone number to call for extra assistance if needed.
Here is a quick link to someplace I just found, scroll down to the bottom its the last one, you wont be able to use some of the kit because it requires the transmission to be out and apart but it is still worth it.
Results for SHIFT KITS:TRANSgo SK KITS
Old 02-23-2010, 05:17 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
For a shop manual check out ebay and also fleet.ford.com for a download.
Old 02-23-2010, 03:35 PM
Thank you gentlemen for the help.
Unfortunately fleet.ford.com requires a password.I remember someone listing a database jam packed with service manuals on another forum I frequent. I'll see if I can dig it up there.
Old 02-25-2010, 09:50 AM
rexpedition99 rexpedition99 is offline
rexpedition99 is starting off with a positive reputation.
OK, since Koolaid and I seem to be having the exact same issue, and I did verify with the dealer that I have the 4R100 tranny, I'll just reply to this thread so we both get the info.
I am about to purchase the shift kit in the above link. Can anyone who has done this job say what special tools might be needed (snap ring pliers, bottle jack)? Also, how difficult is this repair for someone who has worked on cars, but never worked on a tranny before, and how long does it usually take?
Old 02-25-2010, 10:41 AM
http://www.ford-trucks.com/forums/90...t-install.html Have a read here. It seems to be a good how to.
Old 02-25-2010, 11:10 AM
Well, it doesn't look too bad, except for all of the drilling. I wonder if I could just replace the valves and springs to fix the hard shifting?
Old 02-25-2010, 12:27 PM
Rex, we seem to be in just the same boat. I was planning on just replacing the parts in the accumulator valve body but I'll do whatever comes in the kit. I've seen kits that just include the parts for the avb. I'm just glad I won't have to mess with those millions of tiny springs and check ***** that are stuck in some valve bodies. That's what worried me.
BTW thanks for the link!
Old 02-25-2010, 12:48 PM
Actually, according to the linked instructions it looks like you have to pull the plate that has the check ***** in it and possibly move some check *****. I am worried about the check ***** coming out, and the drilling.
I don't have a drill press, and I am worried that if I move the drill too much that I won't get a perfect hole. I am not sure how tight the tolerances is on the holes, but I would rather just fix the hard shifting problem.
Maybe it's not as big of a deal as it sounds, I just want to be cautious.
I couldn't find a smaller kit except for this one, which does not look like it contains the springs.
E40D 4R100 transmission accumulator valves E40D shift kits
Old 02-25-2010, 03:56 PM
jk080's Avatar
Gear Head
You don't have to do the drilling on the separator plate, if I were you guys I would just keep it simple and just remove the acc valve body and replace the springs and the one 1-2 acc valve. This should fix your problem and improve the shifting of the transmission all by itself. You wont have to worry about check ***** or drilling or even unplugging the harness and just so you know the shift kit does not come with valve body gaskets, so if you tear one trying to work on the plate you will be out of luck. Yea you wont be using half the kit but that's ok I don't know of any other kit that just addresses the acc valve body and I am very familiar with the Transgo kit, you should be fine.
*tip*
Use one of the valve body bolts to screw in the end plugs to aid in getting them out of the valve body, you will see when you get there. Use a pick to pop the retaining clips out that hold the plugs in, its ok to bend them up a bit they will straighten out easily.....party on
Old 02-26-2010, 07:07 AM
That's exactly the answer I was hoping for. I wouldn't mind finding a cheaper kit that has just what we need, but my sister will be happy if I can fix her tranny for less than $100.
Should we go ahead and replace the valves and springs for 3rd and 4th since the springs commonly break?
Thanks guys.
Old 02-26-2010, 09:08 AM
jk080's Avatar
Gear Head
Thanks guys.
Just the springs they are also in the kit, you only get one valve in the kit and the 1-2 valve is the only one I have ever seen stick.
Old 06-06-2012, 12:27 PM
expguy121 expguy121 is offline
expguy121 is starting off with a positive reputation.
did you do this?
I am trying to fix my 1-2 accumulator spring. can I not just buy the stuff for the accumulator body? If I do buy the shift kit i just want it to shift like stock. since this is a shift kit if i just use the stuff for the accumulater body will it make it shift ok? I just want a stock shift feel but i may have to buy that kit just to fix mine because i can't find a stock one
Old 06-06-2012, 04:39 PM
jk080's Avatar
Gear Head
Quote:
The spring is not really the problem, the little valve that the spring controls can stick and cause a harsh 1-2 shift. If this is what is going on with your transmission you can simply clean the valve and its bore and it should shift "stock" again. The shift kit gives you a new valve that is not prone to sticking.
Have you checked for codes? If there are any codes stored the harsh 1-2 shift may be due to high line pressure from the computer in a fail safe mode.
Old 06-06-2012, 04:52 PM
I thought the spring is prone to getting broken. Thats where I have read everywhere and I haven't taken mine out yet
4r100 1-2 shift error and gear 2 ratio error richierand95 1999 to 2016 Super Duty 0 08-16-2016 08:51 PM
E4OD shifts hard -fixed- Prototypemech Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 12-24-2013 11:05 PM
Advice on 4R100 rebuild probs Brownie12 1999 - 2003 7.3L Power Stroke Diesel 13 07-06-2013 07:29 PM
e4od accumulator body expguy121 Clutch, Transmission, Differential, Axle & Transfer Case 2 07-07-2012 09:38 AM
harsh 1-2 shift E4OD Midnite1987 1987 - 1996 F150 & Larger F-Series Trucks 5 07-02-2012 08:46 PM
Tags
12, 2, 4r100, drill, ford, hard, harsh, parts, problems, shift, shifts, solenoid, trans, v10, valvebody
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
