Dome Light Override Switch - OOPS
#31
I took a stab at the over ride switch today, getting bruised knuckles in that tiny space. I have a 2000 Ex and have shared 4 picture in my 'various' album. Can someone tell if I'd ID'd the right wire? Seems more blue than black. i guess i can just cut and see what happens...
Thx
Thx
#32
#36
In my '04 Explorer the headlight/dimmer switch assembly looked the same as my '05 Ex, but the dimmer had a detent when you turned it all the way down. When in that position the lights would stay off. Anyone checked into switching switches? I sold my Explorer too quickly after I picked up the Ex to try.
#37
on
The switch from the expy is the same also. You would still need to run another wire tho to the switch to control the override. Stock wiring runs thru a control box first. It is faster/easier to just run a new switch. I have mine mounted in between the rear vent switches on the overhead and it looks nice and stock.
#38
I removed the instrument panel and spliced a wire into the Black / Light blue wire. This wire is located on the connector furthest toward the passenger side. It is the only wire of this color anywhere on the instrument panel. I ran that wire through a toggle switch that I mounted in the dash just to the right of the headlight switch.
Now I control the interior and running board lights with the flip of a switch.............
Thanks a bunch for the wire location, as it's much less footage of wire when using your location(s) of both where to splice and where I wanted my switch as well.
I used a temporary tiny toggle switch, as I want to get a cleaner one (rocker switch) from the local elect. place tomorrow or the next day. Otherwise, I'd have shared pictures too.
#39
I did the same... and LOVE this mod.
#40
Yes sir... speedo, temp, rpm...etc gauge cluster. Remove it's 4 screws, pull it out a bit, and the furthest to the right (towards pass. side) plug... has the black/blue strip wire needed to perform the MOD.
#42
Champ, if you can find that elusive BK/LB wire on a 2000, let me know. I've plumb woreout my neck trying to find that sucker. Easy to find LB with a little BK, but not vice versa on mine.
#43
Man idk. I looked for an hour. I'm just going off what everyone else has said that's it's behind the fuse. I have pulled the 4 bolts that hold the fuse box. It barely moves anyway. Easy to find my butt. Lol.
#44
Agree, the fusebox might move 1.5 inches. Then dig and dig into the bundles. Oops in the title is for nursing those cut and bruised knuckles.
#45
