chip..chip..chipin away at it
#31
John-
It is looking very good! I always consider this phase one of the most rewarding when you see it all coming together after all the dirty work. Keep us updated. I'm looking forward to seeing it all complete. I'm not sure but I think you had taken out the Volare and installing the Mustang II about the time I joined and I'm glad it is nearing completion for you.
#32
wow. your truck is looking great. I cant wait to have my chassis that nice. I jut got the engine running.
Did you box the whole frame?
How wide are those tires? how are you going to get them under the fenders?
great jobs. an Inspiration
Here is my project:
http://www.youtube.com/watch?v=y4YinxYzPuQ
Here is my project:
#33
on
[QUOTE=sofob0909;8614365]wow. your truck is looking great. I cant wait to have my chassis that nice. I jut got the engine running.
nope... just from the front to the cab and a section at the rear where the ladderbars connect to the crossmember
12.5" wide and shortened the rear end 5.5" and will use 4" tubs
john
john
#35
#36
#37
on
a little more progress... yesterday afternoon the plan was to get the lower portion of the front fender ready to mount to the cab (tilt front end)
and start fitting up the tilt front doghouse...
well we quickly realized that to place the fender properly we needed to make sure the running board would fit between fenders...
so we had to mount up the bed sides, clamp on the rear fenders, place the running boards and clamp them...
then check the placement of the front lower fender pieces... 3 hours to do both sides... but all fits properly...
glass work to begin soon. Body man is beefing up the lower fenders...
I'm bending SS tubing bracing for the inside of the hood (stiffener)...
to hold it's shape against the cowl/firewall
pictures will be made this evening... it was way past dark last nite when we finished..
chip chip chip...
later
john
chip chip chip...
later
john
#38
#40
#42
