Differential Fill Plug Removal
Yup that's the way I have done the half dozen or so cars I have needed to do this to. Use the fat short 1/2 drive to 3/8 adapter with a good 1/2 ratchet or breaker bar.
For really stubborn cases you might try some penetrating oil on the threads of maybe a little heat from a torch(careful about too much heat).
When you put the plug back in you might lube the threads or use some antisieze, just a dab.
Good Luck,
Jim Henderson
Good Luck,
Jim Henderson
ExPACamper
59
05-04-2017 09:39 AM
1978Supercab
02-13-2006 03:36 PM
